Apache with SSL as Tomcat Frontend
Postby Megamorf » Sun Aug 14, 2011 2:56 pm
Setup:
- Ubuntu 10.04 x64
- Tomcat 6
- Apache 2.2
Everything is running on one host. The communiction so far looks like this:
[Apache] <-ajp-> [Tomcat]
I configured Apache to use a reverse proxy to communicate with the Tomcat.
Apache:
httpd.conf wrote:
ServerName localhost
LoadModule proxy_module /usr/lib/apache2/modules/mod_proxy.so
LoadModule proxy_ajp_module /usr/lib/apache2/modules/mod_proxy_ajp.so
#LoadModule proxy_balancer_module /usr/lib/apache2/modules/mod_proxy_balancer.so
ProxyRequests Off
ProxyPreserveHost On
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyPass /subsonic ajp://localhost:8009/subsonic
ProxyPassReverse /subsonic ajp://localhost:8009/subsonic
Tomcat
server.xml wrote:<Connector port="8009" protocol="AJP/1.3" redirectPort="8443"/>
I can access the server through http://<apache>/subsonic but I want to use the apache to send the Subsonic http traffic over ssl.
Therefore, I created a self-signed ssl certificate (cert.pem, key.pem) with tinyca and put both in the /etc/apache2/ssl directory.
I put the following in the /etc/apache2/sites-available directory and put a link to the file into the sites-enabled directory.
I read that in some tutorial, but I am not sure if this is really the correct way to do it:
<domainname>-file wrote:<VirtualHost *:443>
ServerName <domain.tld>
SSLEngine on
SSLCertificateKeyFile /etc/apache2/ssl/key.pem
SSLCertificateFile /etc/apache2/ssl/cert.pem
ServerAdmin root@localhost
DocumentRoot /var/www/
</VirtualHost>
How can I achieve that Apache's proxy directory is served through https.
Thanks in advance. :-)
Megamorf
