Android App stops playing when other App is started
Postby Raptor » Mon Aug 22, 2011 9:28 pm
I am currently testing Subsonic and the features look very promising. I am having one big problem with the Android App: It stops playing when I send it into the background and start another App. Sometimes it will continue playing one or two minutes.
I am running Android 2.3.5 (Cyanogen) on a Motorola Milestone (european version of the Droid). Subsonic is the current Market-Version which should be 3.1
I already searched the forums, found one similar issue, but without any solutions. Is anyone else of you experiencing these problems or can I provide more information to fix this?
Raptor
Re: Android App stops playing when other App is started
Postby jsr » Tue Aug 23, 2011 4:46 pm
This seems to be a known issue with CM7 and the original Droid. The Droid doesn't have much memory and the OS is killing programs a little too aggressively.
http://forum.cyanogenmod.com/topic/2585 ... ther-apps/
http://forum.cyanogenmod.com/topic/1762 ... g-quickly/
jsr
Postby Raptor » Tue Aug 23, 2011 4:57 pm
Thank you for the hints. I will try searching in this direction, seems to be my problem. I have to somehow lock the subsonic app to memory...
Edit: For the record: I installed "Swapper for Root" (https://market.android.com/details?id=o ... ee.swapper) and activated a swap file. This does seem to fix the problems with subsonic. It should reduce the sd-card life though, but with todays prices I can live with that
Raptor
