WAV Files not playing
Postby jbraveman » Tue Aug 23, 2011 4:58 pm
I have a few WAV files in my collection that I'd like to listen to. When I try to play them, the player cues the file, but won't play.
[8/23/11 12:43:37 PM EDT] INFO PlaylistInputStream jbraveman listening to "Grateful Dead - 1993-02-23 FOB\gd1993-02-23encore.wav"
[8/23/11 12:43:38 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [\\Media-pc\i\FTP\Grateful Dead - 1993-02-23 FOB\gd1993-02-23encore.wav] [-v] [0] [-f] [wav] [-]
[8/23/11 12:43:38 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [160] [--tt] [gd1993-02-23encore] [--ta] [] [--tl] [Grateful Dead - 1993-02-23 FOB] [-S] [--resample] [44.1] [-] [-]
I'm running this.
Version 4.5 (build 2385) – August 11, 2011
Server jetty-6.1.x, java 1.6.0_26, Windows 7 (41.3 MB / 71.9 MB)
It didn't work on the previous version of subsonic either.
I'm using the default transcoding options wav>mp3:
ffmpeg -i %s -v 0 -f wav -
lame -b %b --tt %t --ta %a --tl %l -S --resample 44.1 - -
Playback of my flacs or mp3s is working fine.
These files are large. Smallest is 112mb, The largest file is nearly 2gb. Incidentally, there is a 600mb flac that won't play either.
I'm wanting to listen to a raw work files from some digital tape transfers.
Thanks for the help.
jbraveman
Re: WAV Files not playing
Postby BKKKPewsey » Tue Aug 23, 2011 5:47 pm
I would try a small (say 8 mb) wave file as a test.
It also looks if your if your memory allocation is a bit low try adjusting it to 256mb in the control panel.
Postby jbraveman » Fri Aug 26, 2011 4:33 pm
My memory is set to 1000. I'm not sure why it says less.
jbraveman
Postby BKKKPewsey » Fri Aug 26, 2011 5:00 pm
Try setting your memory via the control panel to 256mb.
Someone else came up with a similar problem and I wonder if there may be a upper limit which you may have inadvertently passed. :?
Unless you have a very large collection you shouldn't need much more than that.
