Java error?
Java error?
Postby Hjord » Thu Aug 25, 2011 1:54 pm
I get this on the left, where my folders should have been listed.
Error
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_22
Server jetty-6.1.x
Memory Used 91 of 96 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
I'm using
Version 4.5 (build 2385) – 11. august 2011
Server jetty-6.1.x, java 1.6.0_22, Windows 7 (69,4 MB / 96,7 MB)
I get the same error on OSX
But everything else seems to work just fine.
Hjord
Re: Java error?
Postby bushman4 » Thu Aug 25, 2011 2:53 pm
Increase the amount of memory allocated to Subsonic using the Subsonic System Tray helper application. Set it to a higher number (I use 400mb), save it, then stop and restart the Subsonic Service.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Java error?
Postby Hjord » Thu Aug 25, 2011 2:56 pm
How much will you recomend? It's already on 1000mb
Hjord
Re: Java error?
Postby bushman4 » Thu Aug 25, 2011 3:21 pm
I think you must have it set to 100MB, not 1000MB, as evidenced by this line:
Like I said, I use 400mb. By my sig, you can see the size of my collection. How does it compare to yours?
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Java error?
Postby Hjord » Thu Aug 25, 2011 3:41 pm
It was on 1000.
But i reentered 1000 and hit save, but did not have permissions, i fixed that and got it saved and restarted.
But i still get the same error.
Hjord
