Track name issue
Track name issue
Postby bile » Mon Aug 29, 2011 8:10 pm
metaflac --list 01=01_Ghosts_I.flac
comment[0]: ARTIST=Nine Inch Nails
comment[1]: ALBUM=Ghosts I-IV
comment[2]: TITLE=01 Ghosts I
comment[3]: DATE=2008
comment[4]: TRACKNUMBER=01/38
Yet in Subsonic it shows the title as "Ghosts I". All 38 tracks are the same. The track number is right but the name has been stripped of the track number prefix (which is the correct title).
Ghosts I instead of 01 Ghosts I
Ghosts I instead of 02 Ghosts I
Ghosts II instead of 10 Ghosts II
etc.
bile
Re: Track name issue
Postby BKKKPewsey » Tue Aug 30, 2011 2:14 am
bile wrote:Yet in Subsonic it shows the title as "Ghosts I". All 38 tracks are the same. The track number is right but the name has been stripped of the track number prefix (which is the correct title).
etc.
Really?
In that case my SS must be broken :?
Postby bile » Tue Aug 30, 2011 3:02 am
bile
Postby bile » Tue Aug 30, 2011 3:07 am
TITLE: 01 Ghosts I
yet
Now Playing indicates the song is "Ghosts I" as does it send to last.fm.
bile
Postby BKKKPewsey » Tue Aug 30, 2011 3:49 am
As I said before mine must be broken :?
Postby bile » Tue Aug 30, 2011 9:58 am
I don't follow. Isn't that what should happen? Mine's not but should. What version are you using?
bile
Postby BKKKPewsey » Tue Aug 30, 2011 12:52 pm
Yes that is what is suppose to happen :)
I am using v4.5final on server 2003
If you told us what version you had and what you are running on we may be help further
eg: HOW TO ASK FOR HELP
I would also check that the tags display correctly in another media player.
Postby bile » Tue Aug 30, 2011 1:06 pm
4.5 on Ubuntu 11.04. Yes the tags show up correctly elsewhere.
No reason to be a smartass about it.
bile
Postby BKKKPewsey » Tue Aug 30, 2011 4:20 pm
Intrigued in that asking you for some basic information on what you are running and asking you to check the tags in another mediaplayer can be determined as smartass :shock:
As it is clearly not a global SS problem (eg its working fine on windows well on mine at least :) ) we need to establish if its the flac tags / os or something else which is causing the problem.
I would suggest converting 1 or 2 of the files to mp3 and see if they get reported correctly.
Also you could check with a tag editor and see if you have any info in the ID tags (on mine the ID tags are empty)
Postby bile » Tue Aug 30, 2011 4:57 pm
No, being a smartass is posting a photo of your setup not exhibiting the bug I'm experiencing and saying yours must be broken.
bile
Postby bile » Tue Aug 30, 2011 5:06 pm
And yes, ogg vorbis and mp3 both exibit the same behavior. If I change the title from "01 Ghosts I" to "A01 Ghosts I" it shows up correctly as "A01 Ghosts I". Works fine if it's "001 Ghosts I" and "1 Ghosts I". It only strips it when it's two digits.
bile
Postby bile » Tue Aug 30, 2011 5:46 pm
The problem is found in net/sourceforge/subsonic/service/metadata/MetaDataParser.java
title = removeTrackNumberFromTitle(title, metaData.getTrackNumber());
It shouldn't be removing data on an assumption. Any heuristics to figure out metadata should be configurable and off by default.
bile
Postby bushman4 » Tue Aug 30, 2011 5:52 pm
I would suggest that you post this in the "Feature Request" forum and Sindre can make it user configurable if he deems it high enough on the list.
Be as clear as possible, with this supporting information that you just posted, and it has a much better chance of getting done.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
