Pogoplug anyone?
Pogoplug anyone?
Postby Aqualung » Mon Sep 05, 2011 2:58 am
Now that I have Arch Linux ARM on my POGO-E02, I am looking for a FLAC streamer. Would I be able to install Subsonic on my Pogoplug?
Aqualung
Re: Pogoplug anyone?
Postby BKKKPewsey » Mon Sep 05, 2011 3:34 am
I think you will probably get a better response on the ArchlinuxArm forum where you have just been.
But if you read http://archlinuxarm.org/forum/viewtopic.php?f=5&t=185 this will give further info.
Postby hanker » Tue Sep 06, 2011 1:56 pm
Aqualung wrote:Now that I have Arch Linux ARM on my POGO-E02, I am looking for a FLAC streamer. Would I be able to install Subsonic on my Pogoplug?
I have Subsonic running on a Sheevaplug development kit, which is another ARM box. The Sheevaplug boots Debian squeeze from an SDHC card. It's important that you use Sun java and not the open-source one. In my experience, running Subsonic on the Sheevaplug with the open-source java is so slow as to be unusable. With Sun java, it works quite well.
hanker
Postby Aqualung » Tue Sep 06, 2011 2:16 pm
hanker wrote:It's important that you use Sun java and not the open-source one. In my experience, running Subsonic on the Sheevaplug with the open-source java is so slow as to be unusable. With Sun java, it works quite well.
Thanks, I saw the post that advertised using Sun java instead of the open-source one, and I'll keep that in mind. For a while I was toying with the idea of using MPD instead of Subsonic, though someone told me that people are having issues streaming to Android with MPD, so it looks like Subsonic might be my best bet for now.
Thank you for your suggestion, cheers!
Aqualung
