SOLVED: Search Issues
Postby CigDangle » Mon Sep 12, 2011 4:33 pm
I am new to Subsonic, and although I have most of it working great, I'm having an issue using search to locate files I can find by other methods. (Sorry if this is addressed elsewhere; I have been unable to find specific info on this).
Problem Description: I am having problems locating songs using search by title, artist, or album. It ONLY occurs on certain files, and I can find these files by browsing artists. I have about 67,000 songs.
Troubleshooting Steps: I had noticed some errors in the log when updating the search index, but I have since corrected those issues and am not seeing any errors. I have confirmed the tags on the files.
Playback Application and version: I'm seeing the issue using the web interface (4.5), SubAir (0.031), and Subsonic for Android (3.2)
Subsonic Version: 4.5 (build 2385) – August 11, 2011
Server Version: jetty-6.1.x, java 1.6.0_18, Windows 2003 (94.0 MB / 96.7 MB)
Hardware Platform: Windows 2003 Standard x64 Edition - Intel Core2Quad Q6600, 8GB PC2-6400 RAM
Java Memory Limit: 100MB (default)
Problem Filename: n/a
Output from ffmpeg -i:
C:\subsonic\transcode>ffmpeg -i
ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jul 28 2011 01:57:12 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-
runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libo
pencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --
enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger
--enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 11. 0 / 51. 11. 0
  libavcodec   53.  9. 0 / 53.  9. 0
  libavformat  53.  6. 0 / 53.  6. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 27. 3 /  2. 27. 3
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
ffmpeg: missing argument for option 'i'
Last ten log file lines:
[9/12/11 10:39:43 AM CDT]   INFO   SearchService   Created search index with 68000 entries.
[9/12/11 10:39:53 AM CDT]   INFO   SearchService   Created search index with 69000 entries.
[9/12/11 10:40:03 AM CDT]   INFO   SearchService   Created search index with 70000 entries.
[9/12/11 10:40:14 AM CDT]   INFO   SearchService   Created search index with 71000 entries.
[9/12/11 10:40:24 AM CDT]   INFO   SearchService   Created search index with 72000 entries.
[9/12/11 10:40:34 AM CDT]   INFO   SearchService   Created search index with 73000 entries.
[9/12/11 10:40:44 AM CDT]   INFO   SearchService   Created search index with 74000 entries.
[9/12/11 10:40:56 AM CDT]   INFO   SearchService   Created search index with 75000 entries.
[9/12/11 10:41:06 AM CDT]   INFO   SearchService   Created search index with 76000 entries.
[9/12/11 10:44:40 AM CDT]   INFO   SearchService   Created search index with 77000 entries
CigDangle
Re: SOLVED: Search Issues
Postby CigDangle » Mon Sep 12, 2011 5:32 pm
Thanks for anyone who looked or was going to look at this post, but I think I solved my own problem. I simply changed my Java Memory Limit from 100MB (default) to 512MB.
In preliminary testing, it seems the items I was unable to search before are now searchable...
CigDangle
Users browsing this forum: No registered users and 50 guests
