Can't connect to Subsonic all of a sudden
Postby heavy_glow » Fri Sep 16, 2011 3:16 pm
I'm a paying member and use Subsonic nearly everyday, and a couple days ago it just stopped working completely. I'm unable to connect to the server both from my phone (using the 3G service) and via my computer at work. However, when I'm home, I am able to access the web interface when connecting via local host (port 80). I've been troubleshooting this by logging in remotely.
I didn't upgrade to 4.5 immediately, and went ahead and did so thinking this may solve the problem, but to no avail. Everything seems great on the server end. It just won't connect from the outside. I've tried using my registered address and ip address, and still nothing. I've also stopped/started the service a bunch, made sure no multiple instances were running, etc.
I played around with port forwarding a bit, switched the ports, and it could successfully connect via localhost, but never from the outside. I disabled my Windows firewall, and it still wouldn't let me in.
I'm running this on an old Windows XP box. The only thing I could think of was that maybe my ISP was restricting me somehow, but I forwarded my port to 1027, and I still couldn't get through.
Subsonic rocks - and I can't get through my workday without it! Help! :cry:
Other details:
Subsonic Version: 4.5
Server Version: jetty-6.1.x, java 1.6.0_21, Windows XP (28.2 MB / 56.3 MB)
Hardware Platform: Windows XP
Java Memory Limit: 100MB
Last ten log file lines:
[2011-09-16 10:47:10,625] INFO DaoHelper - Checking database schema.
[2011-09-16 10:47:32,500] INFO DaoHelper - Done checking database schema.
[2011-09-16 10:47:45,250] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sat Sep 17 03:00:00 EDT 2011
[2011-09-16 10:47:48,781] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Sep 16 10:52:48 EDT 2011
[2011-09-16 10:48:02,406] INFO NetworkService - Successfully forwarding port 80.
[2011-09-16 10:52:48,781] INFO PodcastService - Starting scheduled Podcast refresh.
[2011-09-16 10:52:48,781] INFO PodcastService - Completed scheduled Podcast refresh.
[2011-09-16 10:59:50,531] INFO VersionService - Resolved local Subsonic version to: 4.5
[2011-09-16 10:59:50,656] INFO VersionService - Resolved latest Subsonic final version to: 4.5
[2011-09-16 10:59:50,656] INFO VersionService - Resolved latest Subsonic beta version to: 4.5.beta2
heavy_glow
Re: Can't connect to Subsonic all of a sudden
Postby BKKKPewsey » Fri Sep 16, 2011 4:16 pm
You say you changed the port but the log is still showing port 80?
Change the port to something else say 8080 - then check with canyouseeme.org to see if the port is open.
Postby bushman4 » Tue Sep 20, 2011 3:16 pm
I'm betting that the internal IP address of the computer running subsonic has changed... can you double check that the IP address that you are forwarding the port to is the actual IP address of the computer running Subsonic?
Just a stab in the dark...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: Exrace and 57 guests
