newbie hardware question for video streaming
Postby baggacfreak » Mon Sep 19, 2011 11:33 am
I am going to buy a new system which should handle following things:
- stream mp3s to my N900 Nokia smartphone with 64k or even less (64k internet flat)
- stream audio within my local lan to a pc or notebook with 128k mp3
- stream video to my girlfriends house via 786k Upstream?!?
- stream video to my N900 Nokia via wlan profil n900 (bitrate might need adjusting
N900 Profil: mp4 - videocodec h.264 - Auflösung 800x480 - Bitrate 1728 - fps Original - aspect - audiocodec AAC - Stereo - Frequenz 44.1 Bitrate - 128.
As hardware equipment I thought following would do:
Intel i5 750 with 8GB Ram and 1 system harddisc with 3 harddiscs in a raid 5 system for video a passiv 512MB Nvidea card.
Is the above mentioned task possible with such a system or would you suggest anything different especially for power usage?
Yours Baggacfreak!
baggacfreak
Re: newbie hardware question for video streaming
Postby Robandcathy » Mon Sep 19, 2011 9:30 pm
Im using a I3 550@3.20GHz
4 Gigs of Ram
12 Terabytes of storage
Windows home server 2011 64 Bit
My ISP Limits upload to 1.2 MB/s
I have had 3 people logged in at same time with no problems.
Your hardware should be more then enough, its your ISP upload limit which will possibly give you an issue.
I watch Blue Ray files from my server on my lan with no probles either.
Pain is a state of mind
Weak minded people feel pain
Robandcathy
Postby baggacfreak » Tue Sep 20, 2011 7:15 am
that upload rat might be not the best, but would it be enough because of the smaller resolution of the Nokia N900 screen? I mean it is not as high res as a blueray or 1024p file.
Yours, baggacfreak.
P.S.: As OS would it be better to choose Win7 64 Bit or Linux?
baggacfreak
