Just registered subsonic, can't get server working
Postby Jmills87 » Fri Sep 30, 2011 7:56 pm
Hello, I have just donated and registered my subsonic license. I am trying to set up my server at .subsonic.org but no matter what name I put in there it says
Status: jmills87.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
And when I try to connect to the server on my iPhone the loading wheel spins forever and eventually says
Unable to connect to Subsonic server
Any ideas? Thanks!
Jmills87
Re: Just registered subsonic, can't get server working
Postby BKKKPewsey » Fri Sep 30, 2011 8:41 pm
Welcome
The first thing is to read this topic http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506
Postby Jmills87 » Fri Sep 30, 2011 8:57 pm
Problem Description: Can't get server working
Troubleshooting Steps: None
Playback Application and version: Z-Subsonic 2.8
Subsonic Version: 4.5 (build 2384)
Server Version: jetty-6.1.x, java 1.6.0_26, Mac OS X
Hardware Platform: Mac
Java Memory Limit: ???
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines: N/A
Jmills87
Postby BKKKPewsey » Fri Sep 30, 2011 9:11 pm
So your next reading task is http://www.subsonic.org/pages/installation.jsp
Can you access on local host?
Have you changed the default port?
Postby Jmills87 » Fri Sep 30, 2011 9:16 pm
Yes, I can access localhost just fine and I have not changed any of the default settings. Thank you :)
Jmills87
Postby BKKKPewsey » Fri Sep 30, 2011 9:23 pm
Settings/network
Status: Does it say successfully registered web address?
Postby Jmills87 » Fri Sep 30, 2011 9:24 pm
Yes, it says:
It gives the same error no matter what name I put in
Jmills87
Postby BKKKPewsey » Fri Sep 30, 2011 9:33 pm
That is because the port is blocked.
On that same page as before, have you ticked the automatically configure your router blah! blah! box?
If you have then UPnP is not working correctly on your router and you will need to forward the port (4040) manually.
Portforward.com will give you further info if required.
Postby Jmills87 » Sat Oct 01, 2011 1:16 am
Ok I will try forwarding manually. Thank you :)
Jmills87
Postby Jmills87 » Sat Oct 01, 2011 3:19 am
Thanks a lot, forwarding port 4040 manually worked! Does this mean that I will have to change the IP address in the port forwarding anytime my dymanic IP changes?
Thanks again!
Jmills87
Postby BKKKPewsey » Sat Oct 01, 2011 11:43 am
Your server should be on a static IP within your lan. With regard to your external IP just use your name.subsonic.org address.
That will take care of that for you automatically.
