Subsonic: Installing on Centos 6
Postby walter » Thu Oct 20, 2011 6:24 pm
Hallo everybody
I had an subsonic installation running on my ubuntu system some time ago.
Now I moved to Centos 6, but I have some trouble using it. I installed it but I'm not able to add music folders. I think it's a permission problem.
I used this post here viewtopic.php?t=5098
To make my installation not running as root. I created a user named subsonic added it to users. All music directories are readable at the moment by subsonic user.
I exactly followed this tutorial and also changes those permissions. Do I have forgot something to change, or does subsonic uses also other directories?
chown -R subsonic:nogroup /tmp/subsonic
chown -R subsonic:nogroup /var/subsonic
chown -R root:root /var/subsonic/transcode
chown -R root:root /var/subsonic/jetty/*/webapp
Subsonic does not find the music.
Help is appreciated
THX in advance
Walter
walter
Re: Subsonic: Installing on Centos 6
Postby Aethies » Fri Oct 21, 2011 1:00 pm
What is your path to the music?
Is it /var/subsonic/music? And I assume you are putting that in the settings screen as well, for your music paths.
I have all my subsonic stuff set to the user:group of subsonic...
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby walter » Sat Oct 22, 2011 11:42 pm
No I added it to users. the subsonic user is also member of group users.
chown -R subsonic:users /tmp/subsonic
chown -R subsonic:users /var/subsonic
But I have tried it again with root access, but it doesn't work. Seems there is no permission problem.
I have my music not in /var/subsonic I have it on another disk (/mnt/disk4/disk4/FLAC/FLAC_KAT1)
Problem Description: Music Folder not being recognised by subsonic.
Troubleshooting Steps: Adding a music folder and scanning it doesn't bring up the music files.
Subsonic Version: 4.5 (build 2384) – August 10, 2011
Server Version: jetty-6.1.x, java 1.6.0_20, Linux (28.3 MB / 89.2 MB)
Hardware Platform: Centos 6.0
Java Memory Limit: 100 mb
Mpeg -i
[walter@localhost ~]$ ffmpeg -i "/mnt/disk4/disk4/FLAC/FLAC_KAT1/Paul Kalkbrenner/Paul Kalkbrenner - Berlin Calling (2008) [FLAC]/03 - Azure.flac"
FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
  built on Dec  4 2010 09:30:59 with gcc 4.4.4 20100726 (Red Hat 4.4.4-13)
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lavf --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Input #0, flac, from '/mnt/disk4/disk4/FLAC/FLAC_KAT1/Paul Kalkbrenner/Paul Kalkbrenner - Berlin Calling (2008) [FLAC]/03 - Azure.flac':
  Metadata:
    ALBUM           : Berlin Calling
    ALBUM ARTIST    : Paul Kalkbrenner
    COMMENT         : EAC (Secure Mode) FLAC -8
    DATE            : 2008
    GENRE           : Soundtrack
    TITLE           : Azure
    TOTALTRACKS     : 14
    TRACKNUMBER     : 03
  Duration: 00:06:11.16, bitrate: 673 kb/s
    Stream #0.0: Audio: flac, 44100 Hz, 2 channels, s16
Log file
[10/22/11 5:07:21 PM CEST]    INFO   DaoHelper   Checking database schema.
[10/22/11 5:07:23 PM CEST]    INFO   DaoHelper   Done checking database schema.
[10/22/11 5:07:25 PM CEST]    INFO   SearchService   Automatic index creation scheduled to run every 1 day(s), starting at Sun Oct 23 03:00:00 CEST 2011
[10/22/11 5:07:25 PM CEST]    INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Oct 22 17:12:25 CEST 2011
[10/22/11 5:07:31 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/22/11 5:12:25 PM CEST]    INFO   PodcastService   Starting scheduled Podcast refresh.
[10/22/11 5:12:25 PM CEST]    INFO   PodcastService   Completed scheduled Podcast refresh.
[10/22/11 6:07:38 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/22/11 7:07:44 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/22/11 8:07:50 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/22/11 9:07:56 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/22/11 10:08:02 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/22/11 11:08:08 PM CEST]    WARN   NetworkService   No UPnP router found.
[10/23/11 12:08:14 AM CEST]    WARN   NetworkService   No UPnP router found.
[10/23/11 1:08:20 AM CEST]    WARN   NetworkService   No UPnP router found.
[10/23/11 1:28:01 AM CEST]    INFO   VersionService   Resolved local Subsonic version to: 4.5
[10/23/11 1:28:01 AM CEST]    INFO   VersionService   Resolved latest Subsonic final version to: 4.5
[10/23/11 1:28:01 AM CEST]    INFO   VersionService   Resolved latest Subsonic beta version to: 4.5.beta2
So here are some more informations. I don't know why it doesn't work. Maybe i have forgot to install something. ffmpeg is installed.
THX
Walter
EDIT: I have copied some files into /var/music and they work perfect. But the files on the other harddisk (mp3) are not being recogised. I'm running Subsonic as root and also changed the owner and the group of the mp3 directory to root.
/var/music (root:root)
/mnt/disk4/disk4/FLAC/FLAC_KAT1 (root:root)
I tested also a folder in the home directory but it also doesn't work. It only works in /var/music
Do I have to edit a config file somewhere?
THX
Walter
walter
Users browsing this forum: No registered users and 44 guests
