Not all albums show up on left side
Postby djandrius » Fri Nov 18, 2011 11:53 pm
Problem Description: I've started to notice that not all Artists are showing up on the left side Artist list. From what I can see, subsonic should show all Folders detected in defined path, however even though I can find with search, album does not show up in the list.
Troubleshooting Steps: Verified I can see and play the song with search. Indexing had no issues finding artist. After indexing is complete in search box I type artist name and it will find it. I can play the song without issues. However it would never show up in the list on left side. That means I can't browse my music collection.
Playback Application and version: Not related to issue.
Subsonic Version: Version 4.6.beta2 (build 2566) – November 16, 2011
Server Version: Server jetty-6.1.x, java 1.6.0_26, Windows 7 (65.5 MB / 97.4 MB)
Hardware Platform: Subsonic on Windows, Network file share on Linux.
Java Memory Limit: 700mb allocated
Problem Filename: Eskmo/2011 - Exclusive Ninja Tune Mix/1 - Eskmo - Exclusive Ninja Tune Mix.mp3
Output from ffmpeg -i: As seen from output below, Artist is Eskmo, however that does not show up in Left pane.
c:\subsonic\transcode\ffmpeg.exe -i "1 - Eskmo - Exclusive Ninja Tune Mix.mp3"
ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jul 28 2011 01:57:12 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --en
able-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 11. 0 / 51. 11. 0
  libavcodec   53.  9. 0 / 53.  9. 0
  libavformat  53.  6. 0 / 53.  6. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 27. 3 /  2. 27. 3
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
[mp3 @ 019E9E80] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 019E9E80] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from '1 - Eskmo - Exclusive Ninja Tune Mix.mp3':
  Metadata:
    artist          : Eskmo
    album           : Exclusive Ninja Tune Mix
    album_artist    : Eskmo
    title           : Exclusive Ninja Tune Mix
    track           : 1
    disc            : 1
    genre           : Electronic
    date            : 2011
  Duration: 00:39:07.80, start: 0.000000, bitrate: 320 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 320 kb/s
Last ten log file lines:
Log
[11/18/11 3:04:50 PM PST]    INFO   DaoHelper   Checking database schema.
[11/18/11 3:04:51 PM PST]    INFO   DaoHelper   Done checking database schema.
[11/18/11 3:04:51 PM PST]    INFO   VersionService   Resolved local Subsonic version to: 4.6.beta2
[11/18/11 3:04:51 PM PST]    INFO   SearchService   Automatic index creation scheduled to run every 1 day(s), starting at Sat Nov 19 05:00:00 PST 2011
[11/18/11 3:04:51 PM PST]    INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Nov 18 15:09:51 PST 2011
[11/18/11 3:04:54 PM PST]    INFO   NetworkService   Successfully forwarding port 4040.
[11/18/11 3:05:08 PM PST]    INFO   VersionService   Resolved latest Subsonic final version to: 4.5
[11/18/11 3:05:08 PM PST]    INFO   VersionService   Resolved latest Subsonic beta version to: 4.6.beta1
[11/18/11 3:09:51 PM PST]    INFO   PodcastService   Starting scheduled Podcast refresh.
[11/18/11 3:09:51 PM PST]    INFO   PodcastService   Completed scheduled Podcast refresh.
[11/18/11 3:21:50 PM PST]    INFO   StreamController   Got range: Range[0,9223372036854775807]
[11/18/11 3:21:50 PM PST]    INFO   PlaylistInputStream   djandrius listening to "2011 - Exclusive Ninja Tune Mix\1 - Eskmo - Exclusive Ninja Tune Mix.mp3"
djandrius
Re: Not all albums show up on left side
Postby BKKKPewsey » Sat Nov 19, 2011 2:44 am
djandrius wrote:Problem Description: I've started to notice that not all Artists are showing up on the left side Artist list. From what I can see, subsonic should show all Folders detected in defined path, however even though I can find with search, album does not show up in the list.
What shows in the left frame is not related to the search index.
djandrius wrote:album does not show up in the list.
Is it Artists or Albums you cannot see :?
What have you told SS where your media folder(s) are and what is the path to the artist/albums that do not show?
Postby djandrius » Sat Nov 19, 2011 10:57 pm
BKKKPewsey wrote:What shows in the left frame is not related to the search index.
I know that. I'm only telling this Artist track is within the define path as it can be found with search, not within the Artist list on left side.
djandrius wrote:Is it Artists or Albums you cannot see :?
Artists on the left side pane.
djandrius wrote:What have you told SS where your media folder(s) are and what is the path to the artist/albums that do not show?
Only one single library is defined. This Artist track is within the same path as entire music library with the same categorizing structure:
<Album artist>/<Year>-<Album>/<Track #>-<Artist>-<Title>
djandrius
Postby Skywatcher » Fri Nov 25, 2011 7:21 pm
I've started suffering from this problem recently as well.
A few artists don't appear on the left pane artist list. Using search it finds the artist without any problems.
On the left pane the previous and following artists appear (same as saying the previous and following folders in the library path). I came to the forums today precisely to see if I could find any other post on it. :?
My directory structure is Music\Artist\Album\Track and Media Folders is pointing to Music\
Skywatcher
Postby Skywatcher » Fri Nov 25, 2011 7:55 pm
So, after googling around a bit more and pressing Ctrl+F5 a few times, I decided to try a trick I found on another site.
I created a new folder (Music2) outside of my library path, copied a few artists there and added that new folder to the media folders list.
Then, on the drop down menu of the left pane I chose to see just the new folder. So those 4 or 5 artists appeared as was to be expected. I then selected All Folders from the drop down list of the left pane and Subsonic took quite a while to rebuild the list, but, guess what, all artists appeared this time. So I just deleted the new folder (the content was a copy) and took it off Media Folders.
If the forced refresh (Ctrl+F5) doesn't work for you, you can always try this trick. It did it for me.
Skywatcher
Postby BKKKPewsey » Fri Nov 25, 2011 10:46 pm
I must admit I am puzzled by this problem and one I have not seen.
Its seems to be the opposite of the usual problem with artists showing in the left frame but not being found by search :?
Postby djandrius » Mon Nov 28, 2011 5:51 am
Skywatcher,
thanks for the tip. I've just tried another computer and it actually loaded Artist name correctly on the left pane. I'll check on my other system that I was exhibiting the problem. I'm almost positive it must be the cookie issue. I'll ensure to get a copy of the cookie and look at the contents. However by looking at the cookie on the system I've just loaded all successfully, I can see the problem:
fetch count:    2
last fetched:    2011-11-27 21:41:52
last modified:    2011-11-27 21:29:28
expires:    2011-12-01 07:04:41
Data size:    5113
My theory is: to check the code in Subsoninc to see what condition(s) forces to ignore the cookie set on a browser and force a full reload. Because I've visited my Subsonic site and cookie was already set, uploading media library did not correctly enforce the code to drop the browser cookie and force a reload.
djandrius
Postby Boutros » Mon Nov 28, 2011 5:41 pm
Hallelujah!!
I'd basically given up on the left pane, as newly-created artist folders basically never showed up there for me (I've been dealing with this problem for months - posted about it on here back in July, but no one could really help). I'd tried Updating Search Index, I tried moving everything to a new folder (from "J:/Artist/Album" to "J:/Music/Artist/Album" structure), and I'd done multiple uninstall/reinstalls. Nothing seemed to solve the problem.
Based on this thread, I did a CTRL-F5, and saw no change. HOWEVER - I then Disabled two auxiliary directories I'd added recently (one for unfiled torrents, one for Soulseek downloads), and lo and behold, the Artist list refreshed with every artist I've added in the last several months.
I love SS more than several members of my immediate family, but this has been a pretty frustrating issue, and I'd love to know if there was fix beyond this workaround. I'm wondering if my 2 dozen users or so will have to go through the same rigamarole to get the full list to populate?
Boutros
Postby Boutros » Tue Nov 29, 2011 3:51 pm
OK, forget my excitement in my previous post. This has not proven to be a durable fix for me.
Yesterday I added several new Artist folders, and an Album in each of them. I did an Update Search Index shortly thereafter.
In the "Recently Added" screen, I see the albums associated with those new Artists. If I search for them, they turn up. However, the left-pane listing is not displaying the new Artist-level folders.
I've done several rounds of CTRL-F5, enabling/disabling various folders (up to and including the primary Music folder), with no effect.
This bug has the effect of creating a sort of shadow directory, where there are albums I can listen to if I remember that they are there and that I want to listen to them. However, my favorite method (just scrolling through the left-hand Artists list until something catches my eye that I want to listen to) is not really possible without leaving out lots of stuff.
Really frustrating.
I should note (if it matters) that I'm running this on a Win7 machine, with the primary Music folder living on a directly-connected external hard-drive - it's not set up as a NAS.
Boutros
Postby djandrius » Tue Nov 29, 2011 4:55 pm
What browser do you use? For Firefox follow http://support.mozilla.com/en-US/kb/Deleting%20cookies Let me know if that fixes in any way. You can also try listing 'about:cache' after you clear your cookies to get more info on the cache.
I haven't added any new entries to my collection, therefore had not encountered this issue again after the last rebuild happened successfully.
djandrius
Postby Boutros » Tue Nov 29, 2011 6:51 pm
Thanks for the insight, djandrius.
I do use Firefox, and just cleared cookies. The missing Artist folders are... still missing.
I just did an about:cache -
On "Memory cache device," the only hit for "subsonic was actually from Facebook, from a share I put up for a friend of mine:
https://www.facebook.com/ajax/metacomposer/attachment/link/scraper.php?scrape_url=http%253A%252F%252Fradiomob.subsonic.org%252Fshare%252FLqSTn&targetid=1133962415&__a=1&xhpc=composerTourStart&nctr[_mod]=pagelet_wall&__user=699180292
(I'ts Blind Willie Johnson, if anyone cares to parse the link in the URL above :))
On "Disk cache device," there were two or three traces of Subsonic, but those look to be album covers that I'd clicked on to enlarge:
https://s-external.ak.fbcdn.net/safe_image.php?d=AQB0P3sq263Wersy&w=90&h=90&url=http%3A%2F%2Fradiomob.subsonic.org%2FcoverArt.view%3FpathUtf8Hex%3D6a3a5c4d757369635c4a6f686e736f6e2c20426c696e642057696c6c69655c5b313932395d2050726169736520476f642049276d205361746973666965645c666f6c6465722e6a7067%26size%3D200
So, yeah... I remain stumped.
Boutros
Postby BKKKPewsey » Tue Nov 29, 2011 7:44 pm
Have a look at your subsonic14.index file with a text editor.
That should have an entry for the artist then entries for all the tracks paths for that artist under that.
Just need to find out if your index file is getting updated correctly.
Postby Boutros » Wed Nov 30, 2011 12:18 am
BKKKPewsey wrote:Have a look at your subsonic14.index file with a text editor.
I'm not super familiar with this, but it all looks correct to me - Count Basie was one of the folders I created (j:\Music\Basie, Count), so here are the first few entries I see:
j:\Music\Basie, Count ixYxi 0 ixYxi BASIE, COUNT ixYxi  ixYxi  ixYxi  ixYxi
A ixYxi 1322570872000 ixYxi 1322570872000 ixYxi j:\Music\Basie, Count\The Complete Decca Recordings ixYxi 0 ixYxi COUNT BASIE ixYxi THE COMPLETE DECCA RECORDINGS ixYxi  ixYxi  ixYxi
F ixYxi 1322570844000 ixYxi 1322570844000 ixYxi j:\Music\Basie, Count\The Complete Decca Recordings\1-01 Honeysuckle Rose.mp3 ixYxi 7326616 ixYxi COUNT BASIE ixYxi THE COMPLETE DECCA RECORDINGS ixYxi HONEYSUCKLE ROSE ixYxi 1937 ixYxi Swing
F ixYxi 1322570844000 ixYxi 1322570844000 ixYxi j:\Music\Basie, Count\The Complete Decca Recordings\1-02 Pennies from Heaven.mp3 ixYxi 7415438 ixYxi COUNT BASIE ixYxi THE COMPLETE DECCA RECORDINGS ixYxi PENNIES FROM HEAVEN ixYxi 1937 ixYxi Swing
F ixYxi 1322570844000 ixYxi 1322570844000 ixYxi j:\Music\Basie, Count\The Complete Decca Recordings\1-03 Swinging at the Daisy Chain.mp3 ixYxi 6953610 ixYxi COUNT BASIE ixYxi THE COMPLETE DECCA RECORDINGS ixYxi SWINGING AT THE DAISY CHAIN ixYxi 1937 ixYxi Swing
Does that all look right to you?
Boutros
Postby BKKKPewsey » Wed Nov 30, 2011 10:50 pm
I was about to write that looks ok then I took another look.
The artist line should start with a "R" eg
R ixYxi 1304182205765 ixYxi 1304182205765 ixYxi D:\shares\music\0\10 c.c ixYxi 0 ixYxi 10 C.C ixYxi  ixYxi  ixYxi  ixYxi
This is then followed by the album starting with "A"
A ixYxi 1306157569859 ixYxi 1306157569859 ixYxi D:\shares\music\0\10 c.c\10 C.C. - The Original Sountrack ixYxi 0 ixYxi 10CC ixYxi THE ORIGINAL SOUNDTRACK ixYxi  ixYxi  ixYxi
I cannot see the "R" on your post - was that just a cut and paste error?
Postby Boutros » Thu Dec 01, 2011 12:18 am
BKKKPewsey wrote:I was about to write that looks ok then I took another look.
Yes, let's call it a cut and paste error :) (Actually, I just didn't know that that was where the artist line starts - like I said above, I'm really not familiar with this).
So, here's a better c/p:
R ixYxi 1322570864000 ixYxi 1322570864000 ixYxi j:\Music\Basie, Count ixYxi 0 ixYxi BASIE, COUNT ixYxi  ixYxi  ixYxi  ixYxi
Boutros
Users browsing this forum: No registered users and 42 guests
