"no playlist available"
Postby revox » Tue Nov 22, 2011 12:06 am
I was originally getting this error: "The playlist folder "/Users/Shared/Playlists" does not exist. Please change the settings" when I attempted to add songs to a playlist. I created that Playlists folder, and now I get a "no playlist available" error.
Is there a secret to creating a playlist?
I'm using a OS X version 10.6.8.
thanks!
revox
Re: "no playlist available"
Postby BKKKPewsey » Tue Nov 22, 2011 12:18 am
Hmm!
  1. Create folder for playlists
  2. Tell SS where it is
  3. Create a playlist
  4. Save a playlist with a name and format you want
  5. Then load playlist
  6. Play
Secret :? don't think so :D
Postby revox » Tue Nov 22, 2011 12:36 am
Everything is set now, but I do not see where to create a playlist! I can create a random playlist, but not a specific playlist.
Is it staring me in the face??
revox
Postby revox » Tue Nov 22, 2011 1:03 am
yeah, it was staring me in the face! thanks for the help. Once I pointed it to the right location everything eventually came together.
Also, I just realized I can export my iTunes playlists to Subsonic. Wonderful! Now I can stream at work.
revox
Postby BKKKPewsey » Tue Nov 22, 2011 1:10 am
:D lot of folks cannot find how to create a random playlist so you are now ahead of the game - enjoy!!
Postby snohio » Thu Dec 15, 2011 4:45 pm
Ahh.. I've been looking for a list of playlists within the top half of the application. The only place on the web frontend to create, add, delete, and LOAD/PLAY a playlist is from the music player (for me the built in player.) Maybe it would be nice to have a place on the main web frame to "modify playlists" or Select Playlists.
snohio
Postby darkdante » Tue Mar 20, 2012 1:09 pm
hello,
i hope sombeody can give me a hint.
i have set the playlist path in subsonic to "/var/playlists", but i can´t find anywhere the option to create a playlist, i only get the error when trying to add some songs to playlist "no playlist available".
i checked the rights on the direcotry "/var/playlists" but they are ok, subsonic should be able to access it. is the button to create playlists on any place i don´t see?
thanks.
kind regards,
daniel
darkdante
