If I click on a web link, Subsonic opens instead
Postby kbec » Mon Dec 05, 2011 6:32 pm
Problem Description: I have subsonic on one of my browser tab. One another tab, I have another web site. If I click a link, subsonic opens at the login prompt instead of the real link from the web.
Troubleshooting Steps: Reinstalled google chrome. Looked at pop up options but nothing there....
Playback Application and version: 4.6.beta2 (build 2566) – November 16, 2011
Subsonic Version: 4.6.beta2 (build 2566) – November 16, 2011
Server Version: jetty-6.1.x, java 1.6.0_20, Windows 7 (59.3 MB / 82.1 MB)
Hardware Platform: Win 7
Java Memory Limit: 100
Problem Filename: NA
Output from ffmpeg -i:
Last ten log file lines: [12/5/11 11:20:42 AM EST] INFO DaoHelper Checking database schema.
[12/5/11 11:20:43 AM EST] INFO Schema46 Updating database schema to version 19.
[12/5/11 11:20:43 AM EST] INFO Schema46 Database table 'transcoding2' not found. Creating it.
[12/5/11 11:20:43 AM EST] INFO Schema46 Database table 'transcoding2' was created successfully.
[12/5/11 11:20:43 AM EST] INFO Schema46 Database table 'player_transcoding2' not found. Creating it.
[12/5/11 11:20:43 AM EST] INFO Schema46 Database table 'player_transcoding2' was created successfully.
[12/5/11 11:20:43 AM EST] INFO Schema46 Database column 'transcoding2.default_active' not found. Creating it.
[12/5/11 11:20:43 AM EST] INFO Schema46 Database column 'transcoding2.default_active' was added successfully.
[12/5/11 11:20:43 AM EST] INFO DaoHelper Done checking database schema.
[12/5/11 11:20:45 AM EST] INFO SearchService Automatic index creation scheduled to run every 1 day(s), starting at Tue Dec 06 04:00:00 EST 2011
[12/5/11 11:20:46 AM EST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Mon Dec 05 11:25:46 EST 2011
[12/5/11 11:20:51 AM EST] WARN NetworkService Failed to find UPnP router using WeUPnP library.
[12/5/11 11:21:09 AM EST] INFO VersionService Resolved local Subsonic version to: 4.6.beta2
[12/5/11 11:21:09 AM EST] INFO VersionService Resolved latest Subsonic final version to: 4.5
[12/5/11 11:21:09 AM EST] INFO VersionService Resolved latest Subsonic beta version to: 4.6.beta1
[12/5/11 11:22:44 AM EST] INFO PlayerDao Created player 5.
[12/5/11 11:23:01 AM EST] INFO NetworkService Successfully forwarding port 80.
[12/5/11 11:23:11 AM EST] INFO PlaylistInputStream admin listening to "Alter Bridge - Blackbird\02 - Alter Bridge - Come To Life.mp3"
[12/5/11 11:25:46 AM EST] INFO PodcastService Starting scheduled Podcast refresh.
[12/5/11 11:25:46 AM EST] INFO PodcastService Completed scheduled Podcast refresh.
[12/5/11 12:23:16 PM EST] WARN NetworkService Failed to find UPnP router using WeUPnP library.
[12/5/11 12:25:24 PM EST] INFO NetworkService Successfully forwarding port 80.
[12/5/11 1:00:22 PM EST] INFO PlaylistInputStream admin listening to "Alter Bridge - Blackbird\03 - Alter Bridge - Brand New Start.mp3"
[12/5/11 1:25:39 PM EST] WARN NetworkService Failed to find UPnP router using WeUPnP library.
[12/5/11 1:27:47 PM EST] INFO NetworkService Successfully forwarding port 80.
kbec
Re: If I click on a web link, Subsonic opens instead
Postby BKKKPewsey » Tue Dec 06, 2011 12:56 am
Change the port to something else NOT 80
That is a default http port and can cause conflicts with other software trying to access the web.
Postby kbec » Wed Apr 18, 2012 6:41 pm
BKKKPewsey wrote:Change the port to something else NOT 80
Can you expand on exactly what I need to do? Change where? I de-installed chrome and using IE. Do I need to change something within IE?
I can't beleive I'm the only one with this issue....
kbec
Postby BKKKPewsey » Wed Apr 18, 2012 7:12 pm
kbec wrote:[12/5/11 1:27:47 PM EST] INFO NetworkService Successfully forwarding port 80.
The port that subsonic is using - change via SS control panel.
Postby GJ51 » Thu Apr 19, 2012 6:19 am
I've sent a request to Sindre to change the Windows default port to 8080 for the next release.
Users browsing this forum: No registered users and 48 guests
