No apps can access subsonic server
Postby sam1am » Fri Dec 16, 2011 7:02 pm
For soe reason suddenly no apps can access my subsonic server. It may have happened with the most recent update (build 2585). I've tried the Android app on two phones and using subair on the desktop. Connection seems to just time out.
Anyone else run into this or have any ideas? Subsonic is running on an Ubuntu server if that helps. I can still access and use the web interface.
sam1am
Re: No apps can access subsonic server
Postby tenzip » Fri Dec 16, 2011 7:50 pm
Can you reach it from another device in the LAN? Assuming you're using private IPs on a LAN, here.
For instance, I have my [user].subsonic.org URL, that will reach my SS server using a public IP:port, or internally, I can use my SS server's private IP, 10.0.0.xxx:port. Most private IPs in home environments will be 192.168.0.xxx, where xxx is a number from 1 to 254.
Are you trying the IP address, or the [user].subsonic.org address?
tenzip
Postby BKKKPewsey » Fri Dec 16, 2011 8:46 pm
I would also check that your SS install is still registered.
The API only works for the registered versions once the 30 day trial expires.
Postby sam1am » Fri Dec 16, 2011 8:47 pm
I'm actually accessing the server from outside using the outside IP address and I have the port forwarded to my box. This is a setup I've had for a long time.
The weird thing is that when I enter my credentials into the android app and his test connection, it reports the connection is okay. If I enter the wrong username or change the server address so it is wrong, I get an error. So it IS talking to subsonic, it's just erroring out as soon as I try to do anything.
sam1am
Postby sam1am » Fri Dec 16, 2011 8:50 pm
BKKKPewsey wrote:I would also check that your SS install is still registered.
I have entered a registration code, but I don't see any way to go see if I currently have a valid one installed or what the status is. It doesn't seem to appear anywhere.
sam1am
Postby BKKKPewsey » Fri Dec 16, 2011 8:59 pm
Yep thats true (I believe its on Sindre's TODO list)
I think you get a donate tab on the home page and also your subsonic.org address will stop working if it thinks its not registered.
Postby sam1am » Fri Dec 16, 2011 9:04 pm
Oddly it began working again as I clicked through all the settings pages again. I wonder if it thought it wasn't registered and I triggered something by going through all the admin pages...? It hasn't worked for days so it can't just be a coincidence that it just started working again, can it?
sam1am
Postby sam1am » Mon Dec 19, 2011 9:48 pm
I kept having issues with subair and subsonic for android not being able to connect, as well as the web interface dropping out and videos disconnecting and having issues all the time. I ended up rolling back to 4.5 and everything seems to work fine again. I think 4.6 has some bugs, and judging by the other posts in here I don't think I'm the only one.
sam1am
