Share Single Files Albums
Postby GatesOfDelirium » Sun Jan 15, 2012 3:22 pm
Firstly just like to say hi and thanks loving subsonic !!
Is there a way to share a download not just share a stream link without opening up the entire server
I have noticed that shared download links work only if the user has "complete download access", not good in my humble opinion
If i remove user download access then obviously links do not appear
Is there a workaround for this or do i need to use a seperate server/ftp etc
Kind Regards
Michael
GatesOfDelirium
GatesOfDelirium
Re: Share Single Files Albums
Postby BKKKPewsey » Sun Jan 15, 2012 8:55 pm
Share links and download have separate check boxes in the create user pages.
So a user can be given share capability but cannot download files.
Postby GatesOfDelirium » Sun Jan 15, 2012 10:20 pm
Thanks For The Reply
the problem is not with the shared media access
My understanding is that the shared media is purely a stream not a download
I am trying to give user access to a single file/album download without opening up the entire server
ie if a guest user logs on with guest guest they can see the entire server and download accordingly dependant on priveleges
I only want to give access to certain downloads not streams
Kind regards
Gates
GatesOfDelirium
Postby ytechie » Sun Jan 15, 2012 10:24 pm
If you only leave the download permission checked, the guest can only download but cannot stream. How about giving us a scenario so that we can better understand your question?
ytechie
Postby GatesOfDelirium » Sun Jan 15, 2012 11:40 pm
Ok Im sorry if i didnt explain too well I appreciate all your help !
i want a user to be able to browse my entire collection : this can be done by giving no permissions all good so far
i then want to be able to provide a download link to a single track or album, "not a stream link" : cant see anyway of doing this; streams work in shared media but there is no way to download that i can see
if I grant a user download rights it appears that they have access to entire server : not good
I simply want to provide a link to a single track or single album that other users can download while restricting download access to the files i choose; not the entire server
or setup a specific share if that is possible
Hope that clears things up a bit better
Kind Regards
Gates
GatesOfDelirium
Postby ytechie » Sun Jan 15, 2012 11:59 pm
So basically what you want is the share functionality with only download abilities. Whatever you share will only be downloadable, not streamable.
Here is where I see the problem: The entire share engine works on the premise that guests cannot download; they can only stream.
Guests are not supposed to download.
ytechie
Postby GatesOfDelirium » Mon Jan 16, 2012 12:58 am
Its more users than guests
a selected group of 5 band members to be precise
so give them a link to a bunch of songs to download so as they can be learned for next gig
I dont want the headache of my isp not happy with the server being abused.
Finally, i thought there maybe some kind of flashvar link for adding a download link in the shared media stream in JWPlayer because that seems to fit what i'm trying to do perfectly.
I just want the users to be able to download for the purpose of playing in their car etc when a website is not available.
I see from browsing that netjukebox and kplaylist have a download function that would work i just much prefer the way subsonic does things plus i dont really fancy running two servers
Kind regards
Gates
Last edited by GatesOfDelirium on Mon Jan 16, 2012 1:17 am, edited 1 time in total.
GatesOfDelirium
Postby ytechie » Mon Jan 16, 2012 1:08 am
Interesting. Thanks for the info - makes it easier to want to really mod this for you! :)
ytechie
Postby GatesOfDelirium » Mon Jan 16, 2012 1:19 am
ytechie wrote:Interesting. Thanks for the info - makes it easier to want to really mod this for you! :)
Its outwith my scope of flash or php programming, lol
GatesOfDelirium
Postby ytechie » Mon Jan 16, 2012 1:23 am
I have to tell you though, I don't think I'm gonna be able to mod this anytime soon. It requires java backend tweaking, which I don't do at the moment. :(
ytechie
Postby GatesOfDelirium » Mon Jan 16, 2012 1:43 am
I'm sure collectively, with all the talented subsonic users, it could be done.
but i fully understand the time constraints
In the interim i'll go down the two servers route until the time is right
Thanks ytechie for your consideration
Kind regards
Gates
GatesOfDelirium
