Cannot connect to server
Postby milesdavisdawg » Sun Jan 22, 2012 4:45 pm
Trying to follow installation instructions,no errors appear in subsonic control panel. server is apparently running. When I click to open subsonic in browser, I get an unable to connect message. unable to connect to localhost.
what am I doing wrong?
milesdavisdawg
Re: Cannot connect to server
Postby ytechie » Sun Jan 22, 2012 5:02 pm
Try http://127.0.0.1 instead of localhost. Keep checking the forums. You're not the first one to have connectivity issues :mrgreen:
ytechie
Postby dando » Fri Jan 27, 2012 11:39 pm
I cannot connect either, and it is not the URL.
After following the instructions explicitly, I was immediately unable to connect - everything was default.
Changing ports does not help. Attempting to connect the following ways does not work:
http://localhost:
http://127.0.0.1:
http://<internal ip>:<port>
So, I tried to telnet to the port, and no connect was found. I port scanned every port on the box, and there are NO subsonic ports open.
It appears that the current build is not listing on the specified port correctly. I tried changing the ports as well, with no luck.
I will follow up if I make any progress.
dando
Postby BKKKPewsey » Fri Jan 27, 2012 11:47 pm
If anyone is having problems with connecting to SS then I suggest a read of viewtopic.php?f=2&t=5506
Also checkout http://monroeworld.com/android/subsonic/
Which has some good practical advice on setting up your server.
Postby GJ51 » Sat Jan 28, 2012 5:57 am
http://forum.subsonic.org/forum/viewforum.php?f=6
Find the most appropriate instructions for your platform. The first one for Windows is very comprehensive and many of the concepts explained are applicable to all installations.
