Sharing a folder or shorcut on external drive
Postby nunya » Mon Jan 23, 2012 7:21 pm
Running out of space so I grabbed an external drive and created a folder on it called "2012_MEDIA"
Sometimes the left.view panel takes a while to load so on main screen i put a link to newer added folders / titles for example
ipaddy.:8080/left.view?musicFolderId=8
which bring folder content of 2012_MEDIA but there is no option to share it & when i add it to shortcuts it also doesnt show
On main music drive i have a folder named "2011_MEDIA" which the shortcut & link to its folder shows up, when i click it it also shows options to share
Is this option available? Or is there a way i can find the permalink code to that folder to share?
for example when i play a title from that folder the link is
http://ipaddy:8080/videoPlayer.view?pat ... opout=true
Is the link to that whole folder in that string somewhere?
Thanks for any help not important of an issue.
nunya
Re: Sharing a folder or shorcut on external drive
Postby ytechie » Mon Jan 23, 2012 9:14 pm
The string is composed of multiple things, one of which is the path encoded in hexadecimal. Go to google, type in "hex to text" and convert the hex to text.
Now, if you want to specify your own path, you can either encode it into hex and set "pathUtf8Hex=", or you can kept it non-encoded and set "path=".
For example, you can access the same thing using an encoded path as with a non-encoded path:
http://ipaddy:8080/videoPlayer.view?path=f:\2012_MEDIA\MOVIES_Flowers_Of_War_2012.avi&maxBitRate=1000&timeOffset=3&popout=true
I use linux, so I don't have the "f:/" which might be a problem for windows users. But maybe escaping it would solve the issue (if it is an issue).
ytechie
Postby nunya » Thu Jan 26, 2012 5:03 pm
Thanks for the info
did the hex to text it usually comes back with a bunch of ?????????? in the string for example
ipaddy:/videoPlayer.view?pathUtf8Hex=663a5c323031325f4d454449415c4d4f564945535f415f4e6f626c655f4c69655f4f6b6c61686f6d615f436974795f313939355f446f63755f323031322e617669
translates to
?????"?????????????ø??f:\2012_MEDIA\MOVIES_A_Noble_Lie_Oklahoma_City_1995_Docu_2012.avi?
at least in windows it does
Im more looking for the string for the folder f:\2012_MEDIA so I can share the folder like I can share my z:\2011_MOVIES folder the difference being the 2011 is on the main music drive and the 2012_MEDIA is on an external drive but there isnt even an option to share folders on other internal drives
and it doesnt even show up in shortcuts just the drop down menu and left view
I also tried ipaddy:/videoPlayer.view?pathUtf8Hex=F:\2012_MEDIA\ & ipaddy/left.view?pathUtf8Hex=F:\2012_MEDIA\
and error page came up
nunya
Postby nunya » Thu Jan 26, 2012 5:29 pm
In short I can link to folder ipaddy/left.view?musicFolderId=8
but cant share it and sharing options dont appear
and i would like to create share link for it would also like to share individual videos like you can albums but when you play video share features dont show
nunya
Postby ytechie » Thu Jan 26, 2012 10:25 pm
Try ipaddy:/videoPlayer.view?path=F:\2012_MEDIA\exact_video.videoExtension.
ytechie
Users browsing this forum: No registered users and 48 guests
