Error preventing Subsonic from working [Resolved]
Postby ChiMatt » Wed Jan 25, 2012 12:42 am
Hey everyone. First off, I want to say that I have had subsonic working for over a year now without issue and it works with my android phone and tablet.
I just started getting the following error and cannot get subsonic to register in any capacity. The tray icon has the following message regardless of what I try.
org.mortbay.util.MultiException[java.net.BindException: Address already in use: bind, java.net.BindException: Address already in use: JVM_Bind]
I have googled the error code and have not found a definitive starting point for fixing the problem. I have paid and have my own registered subsonic subdomain that has been working for sometime without issue. I also checked the router to ensure that multiple instances of subsonic were not running on different ports.
I am out of ideas and would greatly appreciate any help you can provide. Thanks!
Matt
ChiMatt
Re: Error preventing Subsonic from working
Postby ytechie » Wed Jan 25, 2012 12:44 am
The address you specified is being used by someone / something else. Try a different subsonic.org address.
ytechie
Postby ChiMatt » Wed Jan 25, 2012 2:10 am
Thanks for the quick reply, Ytechie. I did a bit more searching on google and found out that it was a port issue. My android tablet connects for ftp transfer on a specific port which was the manual port that I had setup for subsonic. I changed the port on subsonic and my router and we are all good now.
ChiMatt
Re: Error preventing Subsonic from working [Resolved]
Postby an_otter » Fri Sep 14, 2012 12:33 am
Hate to bump old threads, but I'm getting this error now. It happened while I was away from the house, and was working fine up until then. I've changed the port to a few others, which changed the error now to,
Address already in use. Please change port number.
But I get this no matter what port I change it to on the router/control panel.
Any ideas? :/
an_otter
Postby GJ51 » Sat Sep 15, 2012 12:48 am
Reboot the router.
Postby an_otter » Sat Sep 15, 2012 1:24 am
Nada, tried it the first time around. Although the https access worked, so it was definitely a port issue.
But I've since installed the new 4.7 build and it fixed my issue, so we're all set. :)
an_otter
Postby an_otter » Sat Sep 15, 2012 1:54 am
But of course now my Subsonic Android app doesn't connect. But maybe I should make a new thread for that. :/
an_otter
