FLASH ON ANDROID
FLASH ON ANDROID
Postby BOB-CHEWIE » Thu Jan 26, 2012 5:04 am
hello i have come across an ongoing problem...its to do with flashplayer and android phones..well my one at least, i have a samsung galaxy ace, and despite it having flashplayer 10.1 things dont seem to play..eg bbc iplayer as it insists on latest v11 which the android market tells me my device isnt compatible with, well done...
ok so subsonic converts all uploaded video into flash format to stream...well thats where it all falls down..as after going to the hassle of installing winscp and struggling with that for ages..i managed to upload a small video or two to see if subsonic would play that..ok well up comes a miniature version of the windows subsonic screen ..making it hard to read such tiny text ..it asks for flash player ,haha same old problem..so theres no way i can get my videos to play using subsonic..and what about audio? ok thats fun, providing you want subsonic to be no more than a glorified mp3 player..which you can find anywhere..wma? flac? aac? ogg? good luck .its supposed to convert to mp3 to play them..cant even get that to go right..maybe its because the files i have are in 96khz 24bit and some in 5.1 ..do you know i am still trying to find a player that will play video properly in all formats and the same with audio on an android phone and i cant find one..i must have gone through dozens by now...i had to uninstall most of them..same old problem, slow or out of synch badly, or the app hangs up or crashes or audio drops out..so tell me, is it actually impossible to have a multiformat audio / video player on an android device or phone? if the answer is no..then why go on with all these pointless promises that can never be acheived?
BOB-CHEWIE
Re: FLASH ON ANDROID
Postby bushman4 » Fri Jan 27, 2012 3:24 pm
Your root problem is that your phone will not fully support flash. I know of at least five different droid phones that DO work (including my Droid Incredible) because I have personally set them up to access my server.
Currently under consideration is a switch to an HTML5 format instead of the flash format, but there is no announced timeframe (not actual confirmation that it will happen...) so I wouldn't hold your breath.
But i guess, to answer your mostly Rhetorical Question of
I'd say no, it is not impossible. I have done it... I regularly stream all formats of audio and video to my phone. My only real wish would be for full ISO support, but I know that's mostly a pipe dream.
Ciao,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby BKKKPewsey » Fri Jan 27, 2012 4:34 pm
bushman4 wrote:My only real wish would be for full ISO support, but I know that's mostly a pipe dream.
Sindre's TODO List
TODO IN 4.7
Support ISO files.
Your dreams may turn into reality :D
