Upload error
Upload error
Postby Lt.Worf » Sun Jan 29, 2012 8:04 pm
I always get an error when I try to upload a file: Permission denied.
My upload folder is on WinXP NTFS folder. I set folder permission to full access for everyone. I changed service account to administrator.
But nothing works.
Can you help me please?
P.S.
Upload tried from Subsonic admin account, uploads enabled
Subsonic 4.6 (build 2583) – 6. Dezember 2011
jetty-6.1.x, java 1.6.0_30, Windows XP (60,5 MB / 135,1 MB)
WinXP prof. sp3
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby ytechie » Sun Jan 29, 2012 9:18 pm
How did you set full access?
ytechie
Re: Upload error
Postby Lt.Worf » Sun Jan 29, 2012 11:06 pm
I set full access for accounts everyone / administrators / local services / users.
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby Lt.Worf » Sun Jan 29, 2012 11:14 pm
Can please someone tell me if this this feature really works?
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby ytechie » Sun Jan 29, 2012 11:16 pm
It definitely works on my instance of subsonic.
ytechie
Re: Upload error
Postby BKKKPewsey » Sun Jan 29, 2012 11:33 pm
I can concur that it is working on 4.6 final to ntfs directories np.
Check that the file that you are trying to upload is not locked in some form eg. read only
Re: Upload error
Postby Lt.Worf » Mon Jan 30, 2012 6:39 am
The files I try to send are not locked. When I start upload the progress bar is shown an continues to 100% and then the error is shown.
Can you please tell me what security permissions your upload directory has?
Are you running the service with SYSTEM account?
Are you running Windows XP or 7?
Thanks.
P.S.
I just looked in my task-manager and there are TWO tasks "subsonioc-service.exe" running (and one "subsonic-agent.exe" = Task-Icon). Is this ok?
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby GJ51 » Mon Jan 30, 2012 6:49 am
Try changing the Subsonic service logon to the system administrators account.
http://monroeworld.com/android/subsonic/
Re: Upload error
Postby Lt.Worf » Mon Jan 30, 2012 7:07 am
GJ51 wrote:Try changing the Subsonic service logon to the system administrators account.
I already read this link and tried to run the service under my account (my account is administrator account) but this does not help.
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby GJ51 » Mon Jan 30, 2012 7:27 am
I just tested mine and it worked fine even uploading the file to a location on a different server than the one hosting the SS site.
The upload feature is very limited anyway. i just set up Filezilla so that I can upload and manage libraries over ftp. using ftp it's easy to upload multiple folders at one time rather than just one file at a time that then has to be moved to a new folder where you actually want to store it.
It has some use for sending a file to someone else. If you like I can let you try sending one to one of my sites to see if it may be your server or something else.
Re: Upload error
Postby Lt.Worf » Tue Jan 31, 2012 8:43 am
Hallo,
ich hab nun Subsonic mal auf einem Windows7 PC installiert. Und dort hab ich nun genau das gleiche Problem!?
Irgendwie versteh ich das nicht, das es angeblich nur bei mir nicht gehen soll.
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby ytechie » Tue Jan 31, 2012 8:58 am
What's that in English? :)
ytechie
Re: Upload error
Postby Lt.Worf » Tue Jan 31, 2012 4:54 pm
Ups, sorry I was thinking in german :-)
I have installed Subsonic on a Win7 system. There is the same problem!?
What is the difference between your and my machine?
Qapla’
Lt.Worf
Lt.Worf
Re: Upload error
Postby BKKKPewsey » Tue Jan 31, 2012 5:12 pm
Lt.Worf wrote:Ups, sorry I was thinking in german
That's why I had problem with Google translator - I was trying to translate from Klingon
"tlhIngan Hol vIjatlhlaHbe'" :mrgreen:
Re: Upload error
Postby ytechie » Tue Jan 31, 2012 5:35 pm
Well, for one thing, my server is running Ubuntu 10.04.
ytechie
