Re: ffmpeg codec on freebsd 7.3 - error [RESOLVED]
Postby docjay » Wed Feb 01, 2012 4:40 am
Subsonic version: 4.6 (build 2583) – December 6, 2011 - standalone
Running FreeNAS Version: 0.7.2 Sabanda (revision 8191)
OS Version: FreeBSD 7.3-RELEASE-p7 (revision 199506)
Platform: amd64-full
__________________________________________________________________________________
Subsonic Rocks! :D
So this is another question about transcoding, I have read several threads about this, but mainly on just installing the codecs or how to fix them somehow in linux. I have the following codecs installed:
ffmpeg: ffmpeg-0.5_2,1
lame: lame-3.97_1
flac: flac-1.2.1_1
mac: mac-3.99.4.5
I have the default settings for transcoding in 'Settings --> Transcoding'
mp3 audio _____ ogg oga aac m4a flac wav wma aif aiff ape mpc shn _______ mp3 ______ ffmpeg -i %s -ab %bk -v 0 -f mp3 -
I have my entire log posted, but here is the part complaining about transcoding below:
[2012-02-01 04:11:11,491] INFO VersionService - Resolved local Subsonic version to: 4.6
[2012-02-01 04:11:11,654] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-02-01 04:11:11,654] INFO VersionService - Resolved latest Subsonic beta version to: 4.6.beta2
[2012-02-01 04:12:05,038] INFO PlaylistInputStream - admin listening to "Plugged and Unplugged/Warren Haynes - Into The Mystic.flac"
[2012-02-01 04:12:05,041] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/standalone/transcode/ffmpeg] [-i] [/mnt/NASTank/Pub/Music/Warren Haynes/Plugged and Unplugged/Warren Haynes - Into The Mystic.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg) FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-swscale --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-memalign-hack --cc=cc --extra-cflags=-I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib  --extra-libs=-pthread --disable-debug --disable-mmx --disable-libamr-nb --disable-libamr-wb --disable-libdirac --disable-libfaac --enable-libfaad --enable-libfaadbin --disable-libgsm --disable-vhook --enable-ipv6 --disable-libmp3lame --disable-libopenjpeg --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --enable-libvorbis --disable-x11grab --enable-libx264 --enable-libxvid
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libavutil     49.15. 0 / 49.15. 0
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libavcodec    52.20. 0 / 52.20. 0
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libavformat   52.31. 0 / 52.31. 0
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libavdevice   52. 1. 0 / 52. 1. 0
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libavfilter    0. 4. 0 /  0. 4. 0
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libswscale     0. 7. 1 /  0. 7. 1
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   libpostproc   51. 2. 0 / 51. 2. 0
[2012-02-01 04:12:05,080] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   built on Feb 25 2010 23:55:53, gcc: 4.2.1 20070719  [FreeBSD]
[2012-02-01 04:12:05,144] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg) Input #0, flac, from '/mnt/NASTank/Pub/Music/Warren Haynes/Plugged and Unplugged/Warren Haynes - Into The Mystic.flac':
[2012-02-01 04:12:05,144] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   Duration: N/A, bitrate: N/A
[2012-02-01 04:12:05,144] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)     Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[2012-02-01 04:12:05,145] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg) Stream mapping:
[2012-02-01 04:12:05,145] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2012-02-01 04:12:05,145] DEBUG InputStreamReaderThread - (/var/subsonic/standalone/transcode/ffmpeg) Unsupported codec for output stream #0.0
Can anyone help shed some light on this for me? I can't get anything to stream at all since it has to go through the transcoding process. Do I have the wrong version of ffmpeg? If so, what version do I get. I installed the version from the 7.3 branch since that is the version of FreeBSD I'm running.
Any help would be greatly apprecaited! :)
docjay
Postby GJ51 » Wed Feb 01, 2012 6:35 pm
Your ffmpeg is outdated.
Locate the appropriate version and update your ffmpeg to the latest version from here:
http://ffmpeg.org/download.html
The version that originally came with SS should have worked.
Postby docjay » Thu Feb 02, 2012 12:17 am
the latest version I could get a hold of for freenas was ffmpeg-0.7.11_2,1. Freenas does not include any 'make' utilities, so I couldn't compile the latest release of FFMPEG 0.10 dated 1/26/12. I still cannot play .flac or .wma files, my log is below:
2012-02-02 00:05:27,546] WARN NetworkService - No UPnP router found.
[2012-02-02 00:05:31,967] INFO VersionService - Resolved local Subsonic version to: 4.6
[2012-02-02 00:05:32,170] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-02-02 00:05:32,170] INFO VersionService - Resolved latest Subsonic beta version to: 4.6.beta2
[2012-02-02 00:06:00,933] INFO PlaylistInputStream - admin listening to "Plugged and Unplugged/Warren Haynes - Payday.flac"
[2012-02-02 00:06:00,942] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/standalone/transcode/ffmpeg] [-i] [/mnt/NASTank/Pub/Music/Warren Haynes/Plugged and Unplugged/Warren Haynes - Payday.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
there is no error at the end of the log, it just stops with what is seen above.
thank you for your help with this :) Any ideas of where I should go from here?
Jamie
docjay
Postby GJ51 » Thu Feb 02, 2012 12:54 am
Postby docjay » Thu Feb 02, 2012 1:31 am
very funny
docjay
Postby GJ51 » Thu Feb 02, 2012 1:57 am
My apologies. It truly wasn't meant to be. Goolge reported that this link provided an updated version of ffmpeg for freenas. I didn't read the site carefully before posting the link.
Postby docjay » Wed Feb 08, 2012 12:25 am
Well, I hook GJ51's advice and compiled the port of FFMPEG. I installed FREEBSD 7.4 on 'virtualbox' and installed the minimum installation. Then I did a make on the ffmpeg port and when it finally finished, I copied it over to my freenas install (7.3 as above) All worked great on freenas after I copied over a few libraries that it was complaining about that it didn't have. I got those from my virtual FreeBSD install. I copied them over when it asked for one, one by one, until I could run 'ffmpeg' on freenas and it gave me back the correct output for the program. I then put it into its appropriate place for subsonic and now its happy. :mrgreen: its FFmpeg v.7.11 (peace)
I share -- pm if you are looking for help cause I know how much of a bitch it is :evil:
Jamie
docjay
Postby GJ51 » Wed Feb 08, 2012 3:20 am
Glad you got it working, i do know how much time and effort can go into getting everything working right.
Congrats!
