Change SSL port
Change SSL port
Postby daniell » Wed Feb 08, 2012 9:23 am
I'm running my Subsonic on jetty-6.1.x, java 1.6.0_23, Ubuntu Server 11.10, and this works great on https port 443.
But I would like to use this SSL 443 port on apache server where I'm running another webserver.
I guess I need to change this port on subsonic/jetty server, and redirect it in my router to the new port !!
Anybody know what I need and how to do it..
Thnks
Supermicro Intel(R) Core(TM) i7-3555LE CPU @ 2.50GHz, 4 cores 8gb ram
CentOS Linux 6.6 Server, jetty-6.1.x, java 1.7.0_71, Linux (143,2 MB / 437,5 MB) Subsonic 5.1
Supermicro Intel® Atom™ D510 4gb ram
Sophos Security Gateway UTM /v9
daniell
Re: Change SSL port
Postby text » Wed Feb 08, 2012 10:25 am
I think you'll need to change the port number to whatever port you're going to use on the Subsonic control panel. Then, you'll need to go into your routers firewall settings and either add or adjust the port routing to the corresponding port you set up in the control panel. That should do it.
You may (but maybe not) need to add the port number to the server URL... that's assuming you're accessing the server from the android app like I am.
text
Re: Change SSL port
Postby daniell » Wed Feb 08, 2012 10:28 am
I wish it was that simple.. :(
daniell
Re: Change SSL port
Postby bushman4 » Wed Feb 08, 2012 12:44 pm
Why isn't it that simple? Just open the Subsonic Tray icon, change the port, and restart the service.
Then open that port in your firewall.
Your mobile clients should not need any change, and should not even realize any difference.
Hope this helps,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Change SSL port
Postby daniell » Tue Feb 14, 2012 7:18 am
The subsonic is not the problem here, but when i do change the ssl port for subsonic,
it screws up the other services I'm running on Apache2, mail and webserver..
daniell
Re: Change SSL port
Postby mikes » Wed Feb 15, 2012 12:06 am
Well, theres a rude technical term. Changing the subsonic port should have no direct effect on Apache, it just binds to a different port.
mikes
