Podcasts list not updating when podcasts are added or remove
Postby huladaddy » Fri Feb 24, 2012 7:37 am
I added some podcasts. Then later I decided to remove them. Three of them still show up in my list of podcasts when I select my podcast folder from the dropdown folder list in the left pane.
Now that list is static. Whether I add or delete podcasts, the list that shows up in the left pane when I display my podcasts is the same three, even though they don't exist anymore.
Help.
huladaddy
Re: Podcasts list not updating when podcasts are added or re
Postby ytechie » Fri Feb 24, 2012 9:22 am
Did you try resetting your server?
ytechie
Postby huladaddy » Fri Feb 24, 2012 9:53 am
ytechie wrote:Did you try resetting your server?
Yup. No change.
huladaddy
Postby BKKKPewsey » Fri Feb 24, 2012 10:00 pm
To eliminate any cache problems can you delete your browser cache and and the SS jetty cache
Stop SS
subsonic\jetty\xxxx\jsp\org\apache\jsp\Delete what's here
Restart SS
See if that works :roll:
Postby huladaddy » Fri Feb 24, 2012 11:40 pm
No, that didn't work. I wasn't hopeful, because the same incorrect podcast list not only shows up in the web client, but also my other clients.
Any other ideas? I think you are on the right track -- deleting caches...
huladaddy
Postby BKKKPewsey » Sat Feb 25, 2012 2:29 am
OK we now need to look at the SS database.
    Log on to SS with an admin a/c
    Delete the part of the url address that says index.view
    Replace that with db.view (By magic a hidden screen appears :D )
    Type into the database query window
select * from podcast_channel
then hit OK
Are the deleted podcasts listed?
Postby huladaddy » Sat Feb 25, 2012 4:33 am
Nothing gets shown...
huladaddy
Postby BKKKPewsey » Sat Feb 25, 2012 1:47 pm
Have you any podcasts defined? If not can you add one (not 1 of the deleted ones) and try again.
(Want to make sure they are being listed correctly)
Postby huladaddy » Sun Feb 26, 2012 2:16 am
Ok. Added a podcast. It showed up in db.view. Added more. They all showed up.
Maybe clearing the cache earlier helped solve the problem. Seems to be working fine now.
Thanks so much for your help.
huladaddy
