Can't Play Songs from Non-Latin Folders names
Postby Maor_T » Thu Mar 01, 2012 6:51 pm
Hi , I'm using the latest version of subsonic 4.6 beta 2 , and when i open playlists that contains songs from Non-Latin Folders names the playlist is show as empty ,
iv'e tried the version 4.2 and its fixed that , but i want to use the Remote control feature that not working on V4.2
there is any way to fix non-latin folders in V4.6 ?
thank you
Maor_T
Re: Can't Play Songs from Non-Latin Folders names
Postby BKKKPewsey » Thu Mar 01, 2012 7:02 pm
The problem with int. characters is an OS specific problem and as you haven't told us what you are running SS on we cannot really help.
If you do a search of the forum you will find a number of posts that deal with this issue.
There is no problem with SS [4.6] regarding International (utf8) characters using windows (well not on my setup :roll: )
Postby Maor_T » Thu Mar 01, 2012 7:08 pm
sorry , i'm using Windows 7
thanks
Maor_T
Postby BKKKPewsey » Thu Mar 01, 2012 7:20 pm
Ok can you explain what you mean by non-latin characters :?
I assumed that you meant characters with accents éïóâ etc
Postby Maor_T » Thu Mar 01, 2012 7:24 pm
yes - Hebrew
Maor_T
Postby BKKKPewsey » Thu Mar 01, 2012 7:34 pm
Post some of the characters on the board (which is using utf8) and I will test.
Do they display correctly via windows explorer?
Postby Maor_T » Thu Mar 01, 2012 7:46 pm
ok, this is character example
אבגדה
in wibdows explorer its ok
Maor_T
Postby BKKKPewsey » Fri Mar 02, 2012 12:21 am
אבגדה
Using those characters as a template I renamed an mp3 with that name, in a directory with that name and also changed the IDtag title and artist fields to suit.
SS displayed the track (and folder) and played the track np :?
However it really messed up my lastfm scrobble :lol:
Postby Maor_T » Fri Mar 02, 2012 6:29 am
ok..so something is weird in my pc, do yo have any idea what to do ?
you said something about int. characters, what it is?
thank you
Maor_T
Postby Maor_T » Fri Mar 02, 2012 9:53 am
Hi , i also tried to install Subsonic 4.6 beta 2 on different PC and the problem with hebrew folders still happen
if i'm browsing from my android device to the hebrew folders it's ok , but when i load playlist its showen as empty
the problem is only with playlists with hebrew files
Maor_T
Postby BKKKPewsey » Fri Mar 02, 2012 2:59 pm
Update SS to 4.6 final
There was a problem with m3u playlists and utf characters in earlier versions.
If that doesn't work try saving playlists in xspf format which I know worked ok with international characters.
Postby Maor_T » Fri Mar 02, 2012 4:25 pm
this was my fist version that i noticed about the issue...but V4.2 is ok , something in 4.2 fix that
how do i create xspf playlists ?
Maor_T
Postby BKKKPewsey » Fri Mar 02, 2012 7:11 pm
Save playlist - select xspf in drop down box.
Postby Maor_T » Fri Mar 02, 2012 7:16 pm
i don't have this option in winamp or mediamonkey (the palyers that i'm using)
what is your player ?
Maor_T
Postby BKKKPewsey » Fri Mar 02, 2012 7:41 pm
You omitted to say that you are using an external player :?
Those instructions are for using the standard web player.
However both MM and Winamp play m3u files np with Int. characters providing you use external with playlist.
(I have problems getting the external player (no playlist) to work at all :| )
