Subsonic trying to open wrong IP address [Resolved]
Postby smn118 » Sun Mar 11, 2012 2:15 pm
I recently had to reset my router and input all my setting again. For some reason when I login to subsonic it is opening the wrong IP address. It is opening 192.168.3.1/ but my static IP is something different, both of these work for some reason. But subsonic will not connect on my iPhone.
It does say that everything is configured correctly and I am successfully forwarding my ports.
Any help would be greatly appreciated. Thanks!
Im using a Linksys WRT54GL router with current firmware
Mac OSX Lion
smn118
Re: Re: Subsonic trying to open wrong IP address
Postby paulodell » Sun Mar 11, 2012 4:19 pm
smn118 wrote:I recently had to reset my router and input all my setting again. For some reason when I login to subsonic it is opening the wrong IP address. It is opening 192.168.3.1/ but my static IP is something different, both of these work for some reason. But subsonic will not connect on my iPhone.
Mac OSX Lion
Since you changed you ip have you restarted subsonic?
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby smn118 » Sun Mar 11, 2012 4:48 pm
:lol: I swear I restarted at least 5 times in this process, I must've just changed a setting that worked and hadn't restarted it again. Working fine now, thanks for the help lol.
smn118
Re: Subsonic trying to open wrong IP address [Resolved]
Postby smn118 » Wed Mar 14, 2012 9:37 pm
still not working, it'll work for like 2 seconds then stop.
I can not figure out why it is trying to open 192.168.3.1
also when I login through LocalHost/4040 I get a this error
CSRF Security Error
smn118
Postby BKKKPewsey » Wed Mar 14, 2012 11:28 pm
First I would suggest a read of viewtopic.php?f=2&t=5506
How are you trying to login to SS?
