Subsonic 4.5 with Apache Tomcat
Postby species8472jj » Thu Mar 15, 2012 2:15 am
I have been using 4.6, but I had to revert back to 4.5 as 4.6 has some issues with with track length and ogg format.
When I used Tomcat with 4.6, everything was fine. I uninstalled 4.6 to go back to 4.5, and the following happened...
It seems to have installed fine, however when I got to Settings --> Transcoding I get this error... (SS 4.5)
Error
Exception javax.el.PropertyNotFoundException
Message Property 'sourceFormats' not found on type net.sourceforge.subsonic.domain.Transcoding
Java version Sun Microsystems Inc. 1.6.0_31
Operating system Windows XP 5.1
Server Apache Tomcat/6.0.35
Memory Used 33 of 63 MB
If I click on Settings -- General, I get the following error.
Error
Exception org.springframework.beans.NotReadablePropertyException
Message Invalid property 'musicFileTypes' of bean class [net.sourceforge.subsonic.command.GeneralSettingsCommand]: Bean property 'musicFileTypes' is not readable or has an invalid getter method: Does the return type of the getter match the parameter type of the setter?
Memory Used 44 of 63 MB
Stack trace org.springframework.beans.NotReadablePropertyException: Invalid property 'musicFileTypes' of bean class
Any advice would be helpful.
species8472jj
Re: Subsonic 4.5 with Apache Tomcat
Postby GJ51 » Thu Mar 15, 2012 2:48 am
i'd uninstall/reinstall java first. Do not use ver 7 of Java.
Postby species8472jj » Thu Mar 15, 2012 4:16 am
Just tried a reinstall. I'm getting the same errors. I have Java version 6 (not 7).
species8472jj
Postby BKKKPewsey » Thu Mar 15, 2012 1:45 pm
Although this has not been reported on the forum I wonder if there is an incompatibility between 4.6 & 4.5 databases which may be preventing the roll-back.
Try renaming your subsonic dir to subsonic_old and trying another (clean) install.
Postby species8472jj » Thu Mar 15, 2012 3:15 pm
I tried a clean install and unfortunately got the same error.
I am wondering if there is an incompatibility issue.
species8472jj
Postby Beowolf » Thu Mar 15, 2012 5:50 pm
same had issues now back to tomcat 6, and no longer have a webserver but ss is working.....
1,959 artists
1,970 albums
13,978 songs
941.65 GB (~ 14,628 hours)
Beowolf
Postby species8472jj » Thu Mar 15, 2012 6:36 pm
I used Tomcat 6 with Subsonic 4.5, and this is where my issues began (see top of post). SS 4.6 worked fine.
I went back to using a Windows Service and it runs ok, but it is not as fast as when I was using Tomcat.
I am using 4.5 as it works with 4.4's ffmpeg. And I'm using 4.4's ffmpeg, because it is able to transcode mp3 to ogg without issues. And I'm doing that, because my 3G is to slow to handle my mp3's.
Hopefully 4.7 will solve these issues.
species8472jj
Postby GJ51 » Thu Mar 15, 2012 6:46 pm
I've tested 4.7 beta 1 and have it working transcoding mp3 and flac to ogg successfully.
Postby species8472jj » Thu Mar 15, 2012 6:48 pm
Are you using the ffmpeg with 4.7 beta 1 or are you using the ffmpeg with 4.4?
species8472jj
