No media folders found. Please change the settings.
Postby wsalopek » Wed Mar 21, 2012 11:49 pm
Hi guys,
Using v4.6 on a Win 7 machine.
If I put some music in:
c:\music
Subsonic sees it just fine.
But if I try to use my real music folder:
c:\users\bill-asus\my music\itunes\itunes media\music
it does not.
I've been working on this for a few hours to no avail.
Any ideas?
Thanks so much.
wsalopek
Re: No media folders found. Please change the settings.
Postby bushman4 » Thu Mar 22, 2012 12:28 am
Go into the services control panel and set the subsonic service to run with the user account "bill" and the correct password.
The c:\users\<username> folder is only accessible to that particular username by default.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby wsalopek » Tue Jul 31, 2012 10:50 pm
OK...I was able to make that change, but the server still says "No media Folders Found".
And...
Just for other folks clarification. To go to "services": Hit...START, then type in "services.msc".
Then scroll down and double-click SUBSONIC
Click the LOG ON tab
Click the THIS ACCOUNT radio button
Click BROWSE
Type in your computer username (in my case, bill-asus)
Click CHECK NAMES (and you should see the box get filled in with something like "BILL-ASUS-DESK\Bill-Asus")
Click OK
Type in your computer password twice (this is not the same as your Subsonic password)
Click OK
You'll get a message that it worked and you need to stop and restart the Subsonic service
And presto...music should now be found...except that mine was not.
wsalopek
Postby GJ51 » Wed Aug 01, 2012 3:10 am
Sometimes windows folder permission settings get botsed. I'd suggest right-clicking on the folder and reviewing the details of the Security settings to be sure that the sam account you're using for the SS service logon is the same and has FULL CONTROL checked for that user.
We all want our systems to be secure, but all too often they're just too damned secure. :wink:
