but some abuse the privilege!ytechie wrote:If I'm correct, iSub uses the subsonic API to retrieve the artwork for each album. If subsonic only cares about the first instance of album art, then iSub can't know any better.
Globe199 wrote:How can we get this reported as a bug so that it can be fixed?
but some abuse the privilege!BKKKPewsey wrote:Globe199 wrote:How can we get this reported as a bug so that it can be fixed?
Definition of a bug IMHO
Something that doesn't work as described.
Where does it say that SS should display embedded artwork for every file in a folder![]()
I would suggest that, if this important to you, you make a request in the Feature Requests sub-forum
