Accessing subsonic remotely
Re: Accessing subsonic remotely
Postby nimnul » Fri Apr 13, 2012 9:00 am
Excuse my ignorance, I have reistrated a xxx.subsonic.org address and paid for it. But after reinstalling my computer I cant access that anymore. Tried to setup an alternate address, that worked until I rebooted my modem.
I have other things running fine over dyndns and want to use that service instead, where do i Input the dyndns address, the field in network settings is only valid for xxx.subsonic.org addresses.
nimnul
Postby BKKKPewsey » Fri Apr 13, 2012 12:41 pm
nimnul wrote:where do i Input the dyndns address
Ermm! into your browser address bar :?
Postby nimnul » Fri Apr 13, 2012 1:47 pm
I mean when I set up the networksettings:
nimnul
Postby BKKKPewsey » Fri Apr 13, 2012 4:30 pm
You don't - that is for setting up the subsonic.org redirect only.
Postby nimnul » Sat Apr 14, 2012 8:20 am
OK, if I want to use DynDns as "static" IP to reach my server, how do I config that in my phone (iSub).
Or is there a way of checking whether http://<mydomian>.subsonic.org is pointing to the correct IP?
The web interface says "Status: xxxxxxxxxxxx.org is registered, but could not connect to it. (ConnectTimeoutException) "
Where the XXXXXXX is my domain, registrated and licensed.
nimnul
Postby BKKKPewsey » Sat Apr 14, 2012 11:18 am
nimnul wrote:OK, if I want to use DynDns as "static" IP to reach my server, how do I config that in my phone (iSub).
You need to ask that question on the ISub forum
nimnul wrote:Or is there a way of checking whether http://<mydomian>.subsonic.org is pointing to the correct IP?
If you enter the address into a web browser it will come back with your external IP address and port no.
nimnul wrote:Where the XXXXXXX is my domain, registrated and licensed.
The screen shot is showing that SS is still showing unregistered - have you entered your licence details correctly?
I suggest that you check that the port is forwarded correctly use http://canyouseeme.org
Note moved this thread to relevant sub-forum
Postby nimnul » Mon Apr 16, 2012 7:04 am
Went through all settings and eventually it turned out that the modem/first router dropped the DMZ setting when it was rebooted. So I was behind 2 firewalls as opposed to one I had set up properly.
This combined router/modem my ISP forces me to use is PIA.
Thanks for all hints and suggestions BTW.
nimnul
