Album Search not work
Postby naguchennai » Tue May 15, 2012 8:46 am
I used zazeen.com server ... war instalation. Search only search a songs. Not search album. Any one can check my server? where is error?
I updated search index. i deleted lucene files and updated again.. i try all its not work
MOD: Deleted IP address for OP's protection
user:test
pass:test
thank you
naguchennai
Re: Album Search not work
Postby BKKKPewsey » Tue May 15, 2012 10:18 am
Have sent a pm
Postby BKKKPewsey » Tue May 15, 2012 1:41 pm
Ok found a couple of problems
  1. The search index was set to update - never :?
  2. The folder structure will give SS problems
    You need to have the folders set up as Artist\Album\tracks
    At the present you have (I think) set up as alphabet letter\artist or album\tracks
    (Not sure whether they are artists or albums names as I am not very familiar with Indian music :| )
So for example the correct way would be B\The Beatles\Rubber Soul\tracks.
You may also want to change your media folders to point 1 directory down
eg instead of pointing at ..\Music - point at ..\Music\A , ..\Music\B and so on...
This will then display the artists in the left sidebar rather then a generic A, B,C, etc.
Postby naguchennai » Tue May 15, 2012 2:01 pm
Lost time i used gigapros.com server with same music and structure search working fine.. but that was jetty server...
now i am using zazeen.com it is tomcat server...
i added folder structure is A/album/tracks
"A" consider as a Artist. all my tags album name is right one. But when i search with Album name No result.
If possible check again
any explain?
naguchennai
Postby BKKKPewsey » Tue May 15, 2012 3:58 pm
I did and found no change :?
However I did check how you have tagged your files and downloaded 1 file randomly selected.
Hum_Tum_Pe_Marte_Hain_(1999)-Duniya_Se_Kuchh_Lo.mp3
Title tag - not set
Artist tag - contains genre :?
Album tag - not set
Year tag - not set
track no# - not set
Album Artist - not set (not used by SS at the moment)
and from what I can see you still do not have the folders set-up as I said previously
so overall I am surprised (and impressed) that SS can find anything :|
I would suggest you get something like Mp3tag and get busy!!!
Postby naguchennai » Wed May 16, 2012 7:51 am
Ok i created new folder and i changed order as per u told..now folder structure is
A/hindi Movie/Album/Tracks.
now check "agent vinod" it search only songs not album..
I have 100+ album in my album folder..
thank you
naguchennai
Postby hakko » Wed May 16, 2012 8:22 am
Maybe it would be a good idea to add folder A as a "Media folder" inside Subsonic, and folder B as well, and folder C, and folder D ... ?
MusicCabinet developer
hakko
Postby naguchennai » Wed May 16, 2012 8:28 am
I try as per ur sugection.. it also not work
try album name called "Aadmi"
thank you
naguchennai
Postby naguchennai » Wed May 16, 2012 10:57 am
I have another error when i update tags...
Failed to update tags for file------- java.io.IOException: Cannot make changes to file
i thik it is related with search error...
I need chmod any folder?
naguchennai
Postby BKKKPewsey » Thu May 17, 2012 3:08 pm
It would appear that SS does not have write access to that folder/files.
I also tried to update the tags on another folder "Aadmi" - same result.
I would not use subsonic to tag your files though as ,although its ok for quick edits, you need the power of a dedicated tagging program when dealing with a complete library.
(Like using a feather to drive in a nail - can be done with lots of patience - but a hammer is better :lol: )
Postby naguchennai » Thu May 17, 2012 7:55 pm
Ok.. Finally i cant understand... how can i fix my error? this is subsonic bugs???? No solution?
Still search not search album name.. its only happened in zazeen.com server... i also tested some other server with same songs and folder structure...
zazeen.com used tomcat war installation... any zazeen.com user having this issue?
naguchennai
Postby BKKKPewsey » Thu May 17, 2012 9:53 pm
It is not a subsonic "bug" - you need to give SS read/write permissions eg chmod 766
Postby naguchennai » Sun May 20, 2012 12:37 pm
Ok.. Now update tags work... But still album search not work...
Any one know why it not owrk? any help? bug?
naguchennai
Postby naguchennai » Sun May 20, 2012 1:00 pm
Go to zazeen.com demo server... same error album name not work
Web Media Panel MOD:DELETED
Web Media Panel Username: MOD:DELETED
Web Media Panel Password: MOD:DELETED
this is sindre_mehus own hosting service?
thank u
MOD: DO NOT POST YOUR ADMIN A/C DETAILS ON A FORUM POST :shock:
USE THE PM FEATURES
naguchennai
Postby BKKKPewsey » Sun May 20, 2012 1:14 pm
Have you set up the folder structure as I have already indicated :?
