Problem with Subsonic and Java
Postby PasContent » Mon May 21, 2012 11:30 am
Hi there,
I'm getting this error everytime i try to open subsonic : Image
Do you know why ? I'm on a 64bits windows machine (seven).
PasContent
Re: Problem with Subsonic and Java
Postby kyomi7502 » Mon May 21, 2012 2:40 pm
Have you tried (re)installing a 32-bit JDK from that site? I believe the most recent version subsonic works with is java 6 update 32. Go to the java.com website and download that. I'm not sure but I think the 64-bit version includes a 32-bit version as well. It just seems to me like you either haven't updated your java in ages, haven't had java on that machine somehow, or have a corrupted install of java. Re-downloading the correct version on the pc that runs the subsonic server should solve the problem.
kyomi7502
Postby GJ51 » Mon May 21, 2012 3:28 pm
Surest cure is to just uninstall all current Java entries through "Control Panel\All Control Panel Items\Programs and Features" then go to http://www.java.com/en/download/manual.jsp and install the Windows Offline (32-bit) and the Windows Offline (64-bit).
If you get any Java errors after doing that, it's most likely an error in the application.
Postby PasContent » Tue May 22, 2012 9:24 am
GJ51 wrote:Surest cure is to just uninstall all current Java entries through "Control Panel\All Control Panel Items\Programs and Features" then go to http://www.java.com/en/download/manual.jsp and install the Windows Offline (32-bit) and the Windows Offline (64-bit).
Thanks, it works now :D
Solved !
PasContent
