Error with only one folder.
Postby nymusicman » Sat Jun 16, 2012 8:36 pm
I'm running Subsonic 4.7beta2 with Oracle Java 7u5 on Ubuntu 12.04. I've seen the post that says subsonic is incompatible with Java but I have an android phone and except for one folder in my library everything works.
I've increased the memory available to subsonic to 512 in case that was the problem. The name of the folder is CD's. I thought maybe the apostrophe was the problem but it's not a problem with other folders that have them. I'm not sure what else to do. Here is what java spit out inside subsonic
Exception java.lang.IllegalArgumentException
Message Comparison method violates its general contract!
Java version Oracle Corporation 1.7.0_05
Operating system Linux 3.2.0-24-generic
Server jetty-6.1.x
Memory Used 94 of 141 MB
Stack trace java.lang.IllegalArgumentException: Comparison method violates its general contract!
at java.util.TimSort.mergeHi(TimSort.java:868)
at java.util.TimSort.mergeAt(TimSort.java:485)
at java.util.TimSort.mergeForceCollapse(TimSort.java:426)
at java.util.TimSort.sort(TimSort.java:223)
at java.util.TimSort.sort(TimSort.java:173)
at java.util.Arrays.sort(Arrays.java:659)
at java.util.Collections.sort(Collections.java:217)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:212)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:178)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:84)
nymusicman
Re: Error with only one folder.
Postby BKKKPewsey » Sat Jun 16, 2012 8:37 pm
Postby nymusicman » Sat Jun 16, 2012 8:39 pm
Yes I understand that post exists, but running oracle java 7 is the only way to get jukebox mode working. And literally everything else works except this folder. Isn't there another possible option other than just pointing back to a post that I've already said I've read.
nymusicman
Postby GJ51 » Sat Jun 16, 2012 9:39 pm
I'm on Windows and Java 7 runs fine here on multiple servers. Try a reboot?
Postby BKKKPewsey » Sat Jun 16, 2012 10:07 pm
nymusicman wrote:Isn't there another possible option other than just pointing back to a post that I've already said I've read.
After you edited your post 1 minute after I replied :roll:
Postby GJ51 » Sat Jun 16, 2012 10:33 pm
I've got 3 Windows sites running Java 7.4 without problems. When I did get a java error similar to what you've posted, I just rebooted the server and it cleared it up.
HTH
