[7/25/12 5:42:24 PM EDT] DEBUG JukeboxService Closed line com.sun.media.sound.DirectAudioDevice$DirectSDL@f49e8f
[7/25/12 5:42:24 PM EDT] INFO JukeboxService admin stopping jukebox for "(2011) Mission Bell/09 - Learned A Lot.flac"
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) av_interleaved_write_frame(): Operation not permitted
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Received signal 15: terminating.
[7/25/12 5:42:24 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/dorian/flac/Amos Lee/Supply and Demand/01 Shout out loud.flac] [-v] [0] [-f] [au] [-]
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) [flac @ 0xa9e4b20] max_analyze_duration 5000000 reached at 5015510
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, flac, from '/dorian/flac/Amos Lee/Supply and Demand/01 Shout out loud.flac':
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Metadata:
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) DATE : 2006
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ALBUM : Supply and demand
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) GENRE : Pop
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) encoded_by : Exact Audio Copy (Secure mode)
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TITLE : Shout out loud
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ARTIST : Amos Lee
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) track : 1
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:03:52.86, bitrate: 933 kb/s
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, au, to 'pipe:':
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, s16, 1411 kb/s
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[7/25/12 5:42:24 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[7/25/12 5:42:24 PM EDT] DEBUG JukeboxService Opened line com.sun.media.sound.DirectAudioDevice$DirectSDL@990402
[7/25/12 5:42:24 PM EDT] INFO JukeboxService admin starting jukebox for "Supply and Demand/01 Shout out loud.flac"
[7/25/12 5:42:24 PM EDT] DEBUG AudioScrobblerService Successfully registered submission for song 'Learned A Lot' for user iamdooser at Last.fm.
[7/25/12 5:42:25 PM EDT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Shout out loud' for user iamdooser at Last.fm.
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) av_interleaved_write_frame(): Operation not permitted
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Received signal 15: terminating.
[7/25/12 5:44:43 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/dorian/flac/Ben Taylor Band/Famous Among the Barns/10 - Mushroom Dance.flac] [-v] [0] [-f] [au] [-]
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) [flac @ 0xa333b20] max_analyze_duration 5000000 reached at 5015510
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, flac, from '/dorian/flac/Ben Taylor Band/Famous Among the Barns/10 - Mushroom Dance.flac':
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Metadata:
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ENCODER : X Lossless Decoder 20110924
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TITLE : Mushroom Dance
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ARTIST : Ben Taylor Band
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ALBUM : Famous Among the Barns
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) track : 10
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TRACKTOTAL : 12
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TOTALTRACKS : 12
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) DATE : 2003
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:02:20.04, bitrate: 793 kb/s
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, au, to 'pipe:':
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, s16, 1411 kb/s
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[7/25/12 5:44:43 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[7/25/12 5:44:43 PM EDT] DEBUG JukeboxService Opened line com.sun.media.sound.DirectAudioDevice$DirectSDL@130d50a
[7/25/12 5:44:43 PM EDT] INFO JukeboxService admin starting jukebox for "Famous Among the Barns/10 - Mushroom Dance.flac"
[7/25/12 5:44:43 PM EDT] DEBUG AudioScrobblerService Successfully registered submission for song 'Shout out loud' for user iamdooser at Last.fm.
[7/25/12 5:44:44 PM EDT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Mushroom Dance' for user iamdooser at Last.fm.[7/25/12 5:47:24 PM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Jul 26 03:00:00 EDT 2012
[7/25/12 5:47:25 PM EDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Jul 25 17:52:25 EDT 2012
[7/25/12 5:47:27 PM EDT] INFO VersionService Resolved latest Subsonic final version to: 4.6
[7/25/12 5:47:27 PM EDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta2
[7/25/12 5:47:28 PM EDT] INFO NetworkService Deleted port mapping for port 4040
[7/25/12 5:47:50 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/dorian/flac/Branford Marsalis/(2004) Eternal/1 The Ruby And The Pearl.flac] [-v] [0] [-f] [au] [-]
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) [flac @ 0xa1f3b20] max_analyze_duration 5000000 reached at 5015510
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, flac, from '/dorian/flac/Branford Marsalis/(2004) Eternal/1 The Ruby And The Pearl.flac':
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Metadata:
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ALBUM : Eternal
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ARTIST : Branford Marsalis
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) GENRE : Jazz
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) DATE : 2004
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) DESCRIPTION : Track 1
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TITLE : The Ruby And The Pearl
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) track : 1
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ENCODER : Max 0.8.1
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ENCODING : FLAC settings: exhaustiveModelSearch:0 midSideStereo:1 looseMidSideStereo:0 QLPCoeffPrecision:0, ,enableQLPCoeffPrecisionSearch:0, minResidualPartitionOrder:0, maxResidualPartitionOrder:5, maxLPCOrder:8, apodization:tukey(0.5)
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TRACKTOTAL : 7
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:08:55.68, bitrate: 659 kb/s
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, au, to 'pipe:':
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, s16, 1411 kb/s
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[7/25/12 5:47:50 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[7/25/12 5:47:50 PM EDT] DEBUG JukeboxService Opened line com.sun.media.sound.DirectAudioDevice$DirectSDL@1ff8de3
[7/25/12 5:47:50 PM EDT] INFO JukeboxService admin starting jukebox for "(2004) Eternal/1 The Ruby And The Pearl.flac"
[7/25/12 5:47:50 PM EDT] DEBUG AudioScrobblerService Successfully registered now playing for song 'The Ruby And The Pearl' for user iamdooser at Last.fm.[7/25/12 5:50:18 PM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Jul 26 03:00:00 EDT 2012
[7/25/12 5:50:18 PM EDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Jul 25 17:55:18 EDT 2012
[7/25/12 5:50:20 PM EDT] INFO VersionService Resolved latest Subsonic final version to: 4.6
[7/25/12 5:50:20 PM EDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta2
[7/25/12 5:50:21 PM EDT] INFO NetworkService Deleted port mapping for port 4040
[7/25/12 5:50:51 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/dorian/flac/Branford Marsalis/(2004) Eternal/1 The Ruby And The Pearl.flac] [-v] [0] [-f] [au] [-]
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) [flac @ 0x9c4ab20] max_analyze_duration 5000000 reached at 5015510
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, flac, from '/dorian/flac/Branford Marsalis/(2004) Eternal/1 The Ruby And The Pearl.flac':
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Metadata:
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ALBUM : Eternal
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ARTIST : Branford Marsalis
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) GENRE : Jazz
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) DATE : 2004
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) DESCRIPTION : Track 1
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TITLE : The Ruby And The Pearl
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) track : 1
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ENCODER : Max 0.8.1
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) ENCODING : FLAC settings: exhaustiveModelSearch:0 midSideStereo:1 looseMidSideStereo:0 QLPCoeffPrecision:0, ,enableQLPCoeffPrecisionSearch:0, minResidualPartitionOrder:0, maxResidualPartitionOrder:5, maxLPCOrder:8, apodization:tukey(0.5)
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) TRACKTOTAL : 7
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:08:55.68, bitrate: 659 kb/s
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Output #0, au, to 'pipe:':
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, s16, 1411 kb/s
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[7/25/12 5:50:51 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[7/25/12 5:50:51 PM EDT] DEBUG JukeboxService Opened line com.sun.media.sound.DirectAudioDevice$DirectSDL@1c4bcda
[7/25/12 5:50:51 PM EDT] INFO JukeboxService admin starting jukebox for "(2004) Eternal/1 The Ruby And The Pearl.flac"
[7/25/12 5:50:51 PM EDT] DEBUG AudioScrobblerService Successfully registered now playing for song 'The Ruby And The Pearl' for user iamdooser at Last.fm.Users browsing this forum: Bing [Bot] and 21 guests
