Add ID3 tags to LAME encoding for downsampling
Postby GrenDup » Wed Dec 08, 2010 10:05 am
aplus01 wrote:Its working for MP3 in Winamp if you choose "External Player" but not working correctly if you're running "External player w/ playlist".
Is the way that ID3 tags are being created for the player option "External player" different than they way they are created for players that are "External player with playlist"?
When I set my player (using Winamp, BTW) to be "External player" the tags display correctly.
When I use "External player with playlist" the playlist loads correctly with track info but the currently playing track info is replaced with the stream information as shown in the image below
Hello!
Same here!
I'm using:
- Winamp lite 5.601
- Subsonic 4.2 b 1946 (on windows server)
- flac>mp3: "flac -c -s -d %s" then "lame -b 320 - -"
I'd love to see this bug squished... tell me If you need more info/me to experiment something!
Regard
GrenDup
Postby stozher » Wed Dec 08, 2010 2:29 pm
GrenDup check with one step transcoding. You need to install FFmpeg to SS "transcode" directory before:
Step 1: ffmpeg -i %s -f mp3 -ar 44100 -ab 320k -ac 2 -map_meta_data 0:0 -
... step 2 is a blank.
stozher
Postby GrenDup » Wed Dec 08, 2010 6:48 pm
stozher wrote:GrenDup check with one step transcoding. You need to install FFmpeg to SS "transcode" directory before:
This works! Thank you very much sir, you made my day!
I'm finally able to enjoy my "flacs"... too bad it is not possible to stream them directly.
GrenDup
Postby GrenDup » Wed Dec 08, 2010 7:08 pm
New problem: The seek bar.
original config:
- winamp: not working
- webplayer: working
New config (ffmpeg):
- webplayer: working erratically... freeze
is it possible to do something?
Thank you!
GrenDup
Postby stozher » Wed Dec 08, 2010 8:28 pm
Please upgrade some components:
Winamp Media Player: http://www.winamp.com/
Adobe Flash Player: http://get.adobe.com/flashplayer/
FFmpeg Codec: http://www.videohelp.com/tools/ffmpeg (direct link: http://www.videohelp.com/download/ffmpeg-r25512.7z)
* Unzip FFmpeg with a 7-Zip archiver (http://www.7-zip.org/)
NEW: Check seek bar with other player - VLC media player: http://www.videolan.org/vlc/
stozher
Postby GrenDup » Tue Dec 21, 2010 12:53 pm
sorry for the late answer...
all my components are already up to date.
Seek bar doesn't work with VLC either.
regards
GrenDup
Postby GrenDup » Tue Jan 11, 2011 5:16 pm
Hello again!
I migrated my server to Ubuntu 10.10 server x64
ffmpeg version 0.6-4:0.6-2ubuntu6
subsonic 4.3 (build 2078)
I have the same problem as before with the two-steps transcoding in winamp...
When I try with the one step however, I have a new error... It says "error syncing to stream" (I have a screenshot if ever...)
any suggestions? Something to try?
regards!
GrenDup
Postby GrenDup » Tue Feb 08, 2011 5:20 pm
Upgraded to Subsonic 4.4 (build 2169). no luck... Bug's still here!
I also tried with foobar2000 without more luck :-/
Please help :(
GrenDup
It worked!
Postby TheKyle » Wed May 18, 2011 4:47 pm
Thanks! Changing the downsample command to this allowed me to see the ID3 tags in winamp again, even when using "External player with playlist".
TheKyle
Re: Add ID3 tags to LAME encoding for downsampling
Postby GrenDup » Wed Nov 30, 2011 9:29 am
I upgraded to Subsonic 4.6.beta2 and it fixed my problem! Now I see the titles and I'm able to use the search bar in winamp!
I tried to use this transcode: Step 1: ffmpeg -i %s -f mp3 -ar 44100 -ab 320k -ac 2 -map_meta_data 0:0 -
It created an another problem... it divides the playtime in half! :-( strange no?
I then went to settings/players and set the max bitrate of my ext player to: 320k (was set as No Limit before)
Bingo... i'm now able to have 320k, names and search bar!
but I find this strange and not user friendly... well, at least it works.
GrenDup
Postby GrenDup » Sun Jul 08, 2012 12:58 pm
Upgraded from Subsonic 4.6 to 4.7.beta2 (build 3011)
Problem is back :-(
GrenDup
Postby GrenDup » Sat Aug 25, 2012 1:32 pm
I don't know if my post are useful to anybody but...
Upgraded to 4.7.beta3 (build 3060) problem (re-)fixed! (I hope it gonna stay this way!)
GrenDup
Postby GrenDup » Mon Sep 24, 2012 1:50 pm
Well... upgraded to 4.7 (build 3105) Problem is here... again :shock:
GrenDup
Previous
