Support for French
Support for French
Postby PieterB » Wed Sep 19, 2012 2:03 pm
Étienne de Crécy is not listed under 'E', but dumped at the end of the listing under '#', which is not the right way to list a name stating with E-accent aigu.
PB
PieterB
Re: Support for French
Postby hakko » Wed Sep 19, 2012 2:09 pm
You can change which letters get grouped into which index in the settings, though.
MusicCabinet developer
hakko
Postby PieterB » Wed Sep 19, 2012 2:15 pm
hakko wrote:You can change which letters get grouped into which index in the settings, though.
That is true, but then É is listed as a separate letter. I want it to be listed under 'E'.....
PB
PieterB
Postby hakko » Wed Sep 19, 2012 2:20 pm
You can do that, too. Don't remember the syntax but something like E (EÉÈ) to group all of them into E.
hakko
Postby PieterB » Wed Sep 19, 2012 2:44 pm
Interesting! By doing that: E (ÉÈ) there is a white line between the normal E's and É, meaning that entries with É are not listed alphabetical, but at the end of the E-listing.
Maybe there's a way to also solve that issue...
Thanks for your help!
PB
PieterB
Postby hakko » Wed Sep 19, 2012 8:37 pm
I believe that the best way to fix this would be modding the sort algorithm, using this: http://docs.oracle.com/javase/1.5.0/doc ... lator.html
hakko
Postby PieterB » Thu Sep 20, 2012 7:01 am
I do not think modding Subsonic & trying to understand Java - except for some very easy adaptations - is a priority in my life right now. So I'll acccept some little imperfections for now :-)
Since you seem to know more than the average forum member: can you tell me where I can find a listing of users & their email addresses? I stumbled upon that list, somewhere in a file, but cannot reproduce that moment of clarity.
PB
PieterB
Postby hakko » Thu Sep 20, 2012 7:10 am
I would just go to db.view (instead of index.view etc), type select username, email from user in the text box and press the OK button.
hakko
Re: Support for French (resolved)
Postby PieterB » Thu Sep 20, 2012 7:35 am
It feels a little clumsy to ask: where or how can I find/use db.view?
GOT IT: http://localhost:9988/subsonic/db.view
Works great! Thanks for your help!
PB
PieterB
