Usage Statistics reset?
Postby cooperdude » Sat Feb 07, 2009 8:12 pm
Is there a way that a button can be put in place to reset the usage stats for all users? Mine is getting really high for local network usage and its hard to read all the remote usage stats.
Also, how can this be manually reset, what file can I remove?
cooperdude
Postby jannuh » Sat Feb 07, 2009 8:48 pm
Maybe better post it in Help section.
If it isn't possible to reset stats then it would be a nice feature.. ;-)
jannuh
Postby jannuh » Tue Feb 10, 2009 3:28 pm
Anyone with a solution to counter/stats reset?? t.i.a.
jannuh
Postby sindre_mehus » Tue Feb 10, 2009 5:30 pm
It can be done as follows:
1. Log in as admin.
2. Go to http://localhost/db.view
3. Execute the following query:
update user
set bytes_streamed = 0, bytes_downloaded = 0, bytes_uploaded = 0
Hope this helps,
Postby jannuh » Tue Feb 10, 2009 6:06 pm
Thank You Sindre!!
You're dealing with programmers, and ofcourse with noobs, I'm one of the second categorie ofcourse ;-)
jannuh
