Integrate into Logitech Squeezebox
Postby BurnUnit83 » Fri Jun 18, 2010 12:51 am
I would love to simply use Logitech Squeezebox with my windows home server even easier with Subsonic. I already have my playlists and it would be a breeze to use. I would mean I'd actually be able to remove an app from my server that runs dozens upon dozens of apps already.
www.mysqueezebox.com if you want to know the product I speak of. Thanks for all your hard work to date, it's an amazing setup. This would only add to it's awesomeness.
BurnUnit83
Postby thepsychoticneurotic » Thu Sep 23, 2010 3:31 pm
I would second this suggestion - I would even pay for this functionality.
The Squeezebox Server software has become worse and worse ever since Logitech acquired SlimDevices.
Postby BurnUnit83 » Sun Nov 21, 2010 1:08 am
I wold even donate a second time if this became available. =)
BurnUnit83
Postby kwonline1 » Mon Jan 03, 2011 8:52 pm
Here a Solution
1. Add an external Player in Subsonic (with or without Playlist)
Name it "Squeeze"
unselect "Control Player automatically"
let all other settings by default
2. Select Player "Squeeze"
3. Add some Songs to the Playlist an click "Play"
4. In SqueezeCenter go to Internetradio and open URL:
http://<yourServer>/stream?player=<id of your SqueezePlayer>&suffix=.mp3
eg:
http://192.168.1.10:8003/stream?player=18&suffix=.mp3
kwonline1
Re: Integrate into Logitech Squeezebox
Postby nicolash » Sat Apr 14, 2012 8:02 am
UP to this topic, it doesn't work...
Squeezebox/server : 192.168.0.xxx
Subsonic server : out of home in a datacenter
maybe there is a port forward/open needed ?
help :)
And, I think, if it's possible to bypass this awful squeezebox logitech server to keep only subsonic with the hardware of squeeze to stream "good audio", it'll be perfect !
thanks you very much !
edit : after some new try, it works ! only problem is with playlist but thanks you for the tips !
nicolash
Postby doughyjoey5 » Thu May 30, 2013 1:30 pm
Works great! Thanks!
doughyjoey5
