Extending uploading options.
Postby Sounder » Tue Jan 25, 2011 12:52 pm
Dear devs,
Recently I've been uploading data to my subsonic server from remote locations. Although I find the uploading somewhat minimal. For instance a progress bar and an option to upload multiple files at the same time would be more then welcome.
Also when you leave the page for uploading, the upload stops. Maybe its an idea that uploading will continu in the background?
Thanks in advance.
Rens.
The Netherlands.
Sounder
Postby bushman4 » Tue Jan 25, 2011 1:55 pm
You can currently upload more than one file at a time by zipping the files first.
If you create the zip file correctly, you can even upload directory structures, creating directories, subdirectories, etc...
HTH,
Glenn
Postby 3R3 » Tue Jan 25, 2011 3:42 pm
also, until this becomes official check out cyclopes Subsonic Pack 4.4 which adds a upload window so you can browse without aborting the upload.
good luck,
3R3
EDIT: updated link to reflect update of SS Pack from 3.9 to 4.4
3R3
Postby Sounder » Tue Apr 12, 2011 1:55 pm
3R3 wrote:also, until this becomes official check out cyclopes Subsonic Pack 4.4 which adds a upload window so you can browse without aborting the upload.
good luck,
3R3
Cheers that helped.
Sounder
