4.7. Beta2 feedback
4.7. Beta2 feedback
Postby HighCast » Wed Jul 11, 2012 9:26 am
i there,
The software appears to work better than 4.6 stable did.
At least some of the lyrics appear to be working.
Rebuilding the search index is faster after the first run.
Would it be possible to have the option to collapse the playlist view on the left pane? Also other lists should be collapsable.
Is there a way to reduce the system input of debugging information on event list while playing something? It appears to be gathersing really big amount of data to the log.
Is this handled by some registry setting or by something really easily tweakable setting?
HighCast
Re: 4.7. Beta2 feedback
Postby rickeo » Wed Jul 11, 2012 6:07 pm
rickeo
Postby killunit » Wed Jul 11, 2012 11:26 pm
I tried Beta 2 a couple of weeks ago when it was released.
I rolled back to 4.6
Reason: I have a large collection. When Subsonic started up & rescanned it took AGES. Hours. For 2.5GB approx of music
Anyway I am assuming this is to do with the media tag reading on scan rather than filename scanning.
- additionally new folder did not appear immediately when scanning the "parent" folder (such as it was)....
Can the old file scanning feature be re-added please as an option?
For the above performance issues. Also allows me maintain currency then with version & other features/fixes.
Otherwise loving my Subsonic
Jason
killunit
Postby sporkd3 » Thu Jul 12, 2012 7:23 pm
killunit wrote:I tried Beta 2 a couple of weeks ago when it was released.
Jason
Killunit,
I just recently upgraded to 4.7 beta 2 and love it. My music collection is 200GB and the indexing time was DRASTICALLY cut. To the point that when I started the scan I walked away and just a few mins later everything was up.
sporkd3
Postby faralai » Sun Jul 15, 2012 10:46 am
When i select more create random playlist it hasnt work in beta 2.
faralai
Postby chriz239 » Mon Jul 16, 2012 2:30 pm
if i kill Subsonic while scanning media folders it don't come up again until i delete following line(s) in "home/db/subsonic.script similar to:
SET TABLE MEDIA_FILE INDEX'391186288 391143456 391143456 391186896 391142664 391143456 391134728 391406928 391186288 391186288 391186288 391172808 391186288 17653'
Hope you can fix that in stable release, because my media scan takes up to 1 hour.
The "home/db/subsonic.data" file is very big at the beginning of scanning the files. About 400 MB. If the scan has finished the file is about 30 MB. Why is that?
chriz239
Postby HighCast » Tue Jul 17, 2012 10:09 pm
killunit wrote:Reason: I have a large collection. When Subsonic started up & rescanned it took AGES. Hours. For 2.5GB approx of music
5,672 artists
3,636 albums
40,560 songs
292.42 GB
2,947 hours
Works damn fast. Faster than 4.6..
Though, I have no tags - at least much - and the songs are as-is. There's quite large variety of different bitrate MP3's and some FLACs too.
HighCast
