Subsonic 4.7.beta3 released
Re: Subsonic 4.7.beta3 released
Postby rickeo » Mon Aug 27, 2012 4:34 pm
andvaranaut wrote:A new nitpick to report. When you click on the name of a song in the playlist, or in any of the 'action' links along the top of the playlist frame (such as prev/next), the frame jumps to the beginning of the playlist, which is rather annoying. Seems to me that there is a "return false;" missing somewhere. Tested with latest Firefox.
My users are reporting this as well.
rickeo
Postby mystery666 » Tue Aug 28, 2012 6:41 am
Beta 3 seems to have found my previous playlists automatically however when I add songs to them and save them, at some point overnight the songs i added get removed. i'm guessing that the play list files are getting re-imported again.
mystery666
Postby achmetinternet » Tue Aug 28, 2012 8:16 am
achmetinternet wrote:
WIL wrote:
I installed 4.7.beta3 and got Error 503... So reading from passed posts, I renamed my db folder and reinstalled the update. I copied in the files from the old db hoping that I would save my users, but no luck. I was able to point to my music and start a scan. It is pretty quick for the amount I have [867GB]. Now I'm building my users - no biggie at least I have my Subsonic back!
I got this error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/login.view
Powered by jetty://
I am running Subsonic on an Amahi Homeserver. Any idea where I can find the db folder and how to save playlists? Or is this going to be fixed with an update on the next beta?
I tried the suggestion by WIL and what happened is that now I can log oin remotely again but Subsonic tells me that my media folders are empty or "No media folders found. Please change the settings.". This is absolute bogus! All the data is in there so now I don't know what I could do to fix that...
achmetinternet
Postby PieterB » Tue Aug 28, 2012 8:39 am
Maybe too simple, but sometimes things are simple: did you check the settings, i.e. the right path to the media folders? Here no trouble at all. Path remained, users were saved.
My path, which points to a network folder looks like this: \\NasLite-11\Disk-2\Music
PB
PieterB
Postby achmetinternet » Tue Aug 28, 2012 9:01 am
Hi Pieter,
I have the correct paths entered ;)
/var/hda/files/music
achmetinternet
Postby PieterB » Tue Aug 28, 2012 9:16 am
achmetinternet wrote:Hi Pieter,
What is weird (and significant IMHO) that the behavior of the new install seems so unpredictable. Could it be that a Windows install causes less problems then a Linux or Unix install? Apart from some minor problems (sometimes slow M3U upload to the player, but not always; some strange transcoding behavior - maybe connected) everything works - without having to fix anything. I am still using Windows XP SP3.
PB
PieterB
Postby achmetinternet » Tue Aug 28, 2012 11:39 am
I will send my log-file to Sindre and hope he can see what is causing this strange behaviour.
achmetinternet
Postby Muffler » Tue Aug 28, 2012 12:03 pm
So beta 3 brought us HLS. The problem is that i don't have any iDevice so i can't test it out. Should it work by itself or are there any dependencies? I have some iPad users who have tried to watch video clips but everyone still gets the "flash player required" in the browser and audio only (and a black screen) in the app SubStream.
I found the transcoding string in the transcoding settings that says ffmpeg -ss %o -t %d -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f mpegts -vcodec libx264 -preset superfast -acodec libmp3lame -threads 0 -
Would appreciate any help!
Daniel
Muffler
Postby achmetinternet » Tue Aug 28, 2012 5:31 pm
Here is the log from subsonic.log:
[2012-08-28 08:08:39,758] INFO DaoHelper - Checking database schema.
[2012-08-28 08:08:40,218] INFO DaoHelper - Done checking database schema.
[2012-08-28 08:08:40,305] INFO VersionService - Resolved local Subsonic version to: 4.7.beta3
[2012-08-28 08:08:40,556] INFO PlayerDao - Deleted 1 player(s) that haven't been used after Fri Jun 29 08:08:40 CEST 2012
[2012-08-28 08:08:40,636] INFO MediaScannerService - Deleted old index file: /var/subsonic/subsonic14.index
[2012-08-28 08:08:40,637] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 08:08:40,706] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Aug 28 08:13:40 CEST 2012
[2012-08-28 08:08:43,799] INFO NetworkService - Deleted port mapping for port 4040
[2012-08-28 08:08:52,350] INFO PlayerDao - Created player 1.
[2012-08-28 08:08:52,950] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-08-28 08:08:52,950] INFO VersionService - Resolved latest Subsonic beta version to: 4.7.beta3
[2012-08-28 08:13:40,707] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-08-28 08:13:40,708] INFO PodcastService - Completed scheduled Podcast refresh.
[2012-08-28 09:03:17,524] INFO PlayerDao - Created player 2.
[2012-08-28 09:05:25,784] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 09:05:29,218] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:05:29,297] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:05:29,297] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:05:29,300] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:05:29,301] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:05:29,306] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:09:28,231] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 09:09:30,526] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:09:30,530] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:09:30,530] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:09:30,531] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:09:30,531] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:09:30,532] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:09:37,795] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:09:37,799] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:09:37,800] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:09:37,806] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:09:37,807] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:09:37,808] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:09:48,243] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 09:09:51,929] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:09:51,934] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:09:51,934] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:09:51,935] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:09:51,936] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:09:51,938] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:10:26,258] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:10:26,309] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:10:26,309] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:10:26,310] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:10:26,311] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:10:26,312] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:11:20,946] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 09:11:23,065] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:11:23,071] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:11:23,071] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:11:23,072] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:11:23,073] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:11:23,073] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:12:45,636] INFO MusicFolderDao - Created music folder /var/hda/files/Torrents
[2012-08-28 09:12:45,638] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 09:12:48,917] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:12:48,922] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:12:48,922] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:12:48,923] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:12:48,924] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:12:48,926] INFO MediaScannerService - Completed media library scan.
[2012-08-28 09:13:23,113] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 29 03:00:00 CEST 2012
[2012-08-28 09:13:41,844] INFO MediaScannerService - Starting to scan media library.
[2012-08-28 09:13:41,847] INFO MediaScannerService - Scanned media library with 0 entries.
[2012-08-28 09:13:41,847] INFO MediaScannerService - Marking non-present files.
[2012-08-28 09:13:41,848] INFO MediaScannerService - Marking non-present artists.
[2012-08-28 09:13:41,848] INFO MediaScannerService - Marking non-present albums.
[2012-08-28 09:13:41,849] INFO MediaScannerService - Completed media library scan.
[2012-08-28 19:16:54,715] INFO PlayerDao - Created player 3.
And here is the log from subsonic_sh.log:
24 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@5a8a0d5d: display name [org.springframework.context.support.ClassPathXmlApplicationContext@5a8a0d5d]; startup date [Tue Aug 28 08:08:38 CEST 2012]; root of context hierarchy
66 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
331 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@5a8a0d5d]: org.springframework.beans.factory.support.DefaultListableBeanFactory@199836ed
340 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@199836ed: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
356 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/3060
380 [main] INFO org.mortbay.log - jetty-6.1.x
404 [main] INFO org.mortbay.log - Extract jar:file:/usr/share/subsonic/subsonic.war!/ to /var/subsonic/jetty/3060/webapp
[GC 15488K->586K(59264K), 0.0020560 secs]
[GC 16074K->682K(59264K), 0.0011460 secs]
[GC 16165K->1056K(59264K), 0.0018050 secs]
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/var/subsonic/jetty/3060/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
1282 [main] INFO / - Initializing Spring root WebApplicationContext
1282 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
1315 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@6a969c29: display name [Root WebApplicationContext]; startup date [Tue Aug 28 08:08:39 CEST 2012]; root of context hierarchy
1367 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
[GC 16544K->1468K(59264K), 0.0023530 secs]
1484 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
1532 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
1559 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@6a969c29]: org.springframework.beans.factory.support.DefaultListableBeanFactory@8691dee
1706 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@8691dee: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,musicFileMemoryCache]; root of factory hierarchy
1743 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
[GC 16956K->3783K(58880K), 0.0034600 secs]
[GC 18887K->5033K(58688K), 0.0076690 secs]
[GC 19113K->6633K(59712K), 0.0073170 secs]
2846 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
2854 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
2854 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(int,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
2854 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
2876 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 1594 ms
2904 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
2904 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
2904 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@92ca580: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Tue Aug 28 08:08:40 CEST 2012]; parent: org.springframework.web.context.support.XmlWebApplicationContext@6a969c29
2904 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
2988 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@92ca580]: org.springframework.beans.factory.support.DefaultListableBeanFactory@4bb963c4
[GC 20713K->7843K(74176K), 0.0150880 secs]
3090 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@4bb963c4: defining beans [leftController,rightController,statusController,mainController,playlistController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,hlsController,videoPlayerController,externalPlayerController,downloadController,donateController,multiController,wapController,restController,dbController,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@8691dee
3513 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 609 ms
3523 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
3549 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
3554 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
3576 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
[GC 32670K->9589K(75008K), 0.0173120 secs]
[Full GC 9589K->9472K(75008K), 0.0642560 secs]
[GC 36800K->10506K(76288K), 0.0055320 secs]
[GC 38730K->11786K(76224K), 0.0043960 secs]
[GC 40010K->12811K(85440K), 0.0086210 secs]
[GC 50571K->14741K(85376K), 0.0044470 secs]
15172 [btpool0-3] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0.116.rc1 on jetty-6.1.x / JDK 1.6.0_24 from Sun Microsystems Inc. at
[GC 52501K->19117K(84864K), 0.0102000 secs]
[GC 56749K->22346K(84736K), 0.0132910 secs]
[GC 59978K->31951K(76672K), 0.0746360 secs]
[GC 59983K->31615K(80832K), 0.0157760 secs]
[GC 59647K->32067K(80384K), 0.0039410 secs]
[GC 60163K->32617K(80640K), 0.0027600 secs]
[GC 60713K->32788K(77312K), 0.0044040 secs]
[GC 41278K->32847K(68608K), 0.0030450 secs]
[Full GC 32847K->28187K(68608K), 0.1391360 secs]
[GC 55387K->28763K(76416K), 0.0029490 secs]
[GC 46054K->28651K(67904K), 0.0041330 secs]
[Full GC 28651K->28235K(67904K), 0.1199630 secs]
[GC 30204K->28363K(76480K), 0.0014900 secs]
[Full GC 28363K->26060K(76480K), 0.1325160 secs]
[GC 52415K->26524K(67328K), 0.0024480 secs]
[GC 52124K->26436K(73344K), 0.0022930 secs]
[GC 51268K->26476K(65728K), 0.0013200 secs]
[GC 50604K->26484K(71168K), 0.0027830 secs]
[GC 49908K->26652K(64384K), 0.0019260 secs]
[GC 30523K->26436K(70464K), 0.0016030 secs]
[Full GC 26436K->26406K(70464K), 0.1116340 secs]
[GC 49126K->26694K(63616K), 0.0018400 secs]
[GC 48774K->26742K(67648K), 0.0016880 secs]
[GC 48182K->26718K(62336K), 0.0024410 secs]
[GC 47582K->26694K(65856K), 0.0018340 secs]
[GC 46982K->26734K(61248K), 0.0016950 secs]
[GC 36684K->26614K(65472K), 0.0009250 secs]
[Full GC 26614K->26575K(65472K), 0.1435410 secs]
[GC 46351K->26799K(60736K), 0.0024060 secs]
[GC 46063K->26823K(63360K), 0.0021420 secs]
[GC 45575K->26807K(59648K), 0.0022680 secs]
[GC 45047K->26879K(61888K), 0.0016550 secs]
[GC 44671K->26887K(58816K), 0.0016770 secs]
[GC 44231K->26895K(60544K), 0.0017130 secs]
[GC 31064K->26711K(58176K), 0.0015790 secs]
[Full GC 26711K->26685K(58176K), 0.1114140 secs]
[GC 43581K->26941K(59904K), 0.0017460 secs]
[GC 43453K->26933K(57600K), 0.0020390 secs]
[GC 43061K->26877K(58752K), 0.0065310 secs]
[GC 42621K->26917K(56768K), 0.0016010 secs]
[GC 42277K->26893K(57920K), 0.0014670 secs]
[GC 41933K->26901K(56128K), 0.0014350 secs]
[GC 41621K->26909K(57024K), 0.0020290 secs]
[GC 31732K->26853K(55744K), 0.0015450 secs]
[Full GC 26853K->25541K(55744K), 0.1243640 secs]
[GC 39941K->25733K(56448K), 0.0016960 secs]
[GC 39813K->25717K(55168K), 0.0016030 secs]
[GC 39477K->25757K(55680K), 0.0016840 secs]
[GC 39197K->25925K(54784K), 0.0014300 secs]
[GC 39109K->25885K(55040K), 0.0017550 secs]
[GC 38813K->25893K(54144K), 0.0021170 secs]
[GC 38565K->25933K(54272K), 0.0049770 secs]
[GC 38349K->25909K(53632K), 0.0015470 secs]
[GC 35426K->26013K(54208K), 0.0018520 secs]
[Full GC 26013K->25972K(54208K), 0.1121730 secs]
[GC 32431K->26100K(54272K), 0.0103700 secs]
[Full GC 26100K->26020K(54272K), 0.1132840 secs]
[GC 27402K->26084K(54144K), 0.0010550 secs]
[Full GC 26084K->26023K(54144K), 0.1213180 secs]
[GC 27316K->26055K(54208K), 0.0008940 secs]
[Full GC 26055K->25492K(54208K), 0.1187170 secs]
[GC 26874K->25556K(54080K), 0.0009810 secs]
[Full GC 25556K->25495K(54080K), 0.1143020 secs]
[GC 26788K->25527K(54144K), 0.0009670 secs]
[Full GC 25527K->25495K(54144K), 0.1727640 secs]
achmetinternet
Postby achmetinternet » Tue Aug 28, 2012 5:36 pm
Very strange...I just went into my server and did the folder setup there and now it worked...it is being scanned properly.
achmetinternet
Postby squipple » Tue Aug 28, 2012 7:45 pm
Year sorting! Hi-5 Sindre!
squipple
Postby mystery666 » Wed Aug 29, 2012 2:56 am
mystery666 wrote:Beta 3 seems to have found my previous playlists automatically however when I add songs to them and save them, at some point overnight the songs i added get removed. i'm guessing that the play list files are getting re-imported again.
Never mind. I just realized i have 45 playlists now because every time i add a song and "save as playlist" its creating a new playlist, which is completely different than before.
mystery666
Postby BKKKPewsey » Wed Aug 29, 2012 3:12 pm
I have noticed that the browser seems reluctant to display album art on occasions.
Not sure whether its due to browser cache issues or SS slow in creating the art thumbnails.
After a few browser refreshes I can usually get the art to display but it does seem to be worse with 4.7 then 4.6.
'Deep' link & JPG in the root folder
Postby PieterB » Thu Aug 30, 2012 2:47 pm
If you have a folder called 'Avant Garde Project', and in that folder is a sub-folder called 'Ondes Martenot' which contains three cd's in separate folders, no JPG is shown in the 'Avant Garde Project' listing. Even if you put a JPG in the root of the folder 'Ondes Martenot', no JPG is shown in the listing.
That means that Subsonic does not 'see' the three cd's hidden in the 'Ondes Martenot' folder, but also discards the JPG in the root of the folder. Probably because there's no music file in that root.
In previous versions, the deep link was absent as well, but Subsonic did show a picture in the root folder.
Hope this gets repaired....
PB
PB
PieterB
Now Playing
Postby PieterB » Thu Aug 30, 2012 3:11 pm
I would like to be able to see in the 'Now Playing' listing, if a user is listening to a radio station or a podcast. Can that be arranged in the next release?
(politely asking)
PB
PB
PieterB
Return to Announcements
Users browsing this forum: No registered users and 35 guests
