Windows 8 client
Re: Windows 8 client
Postby Yanos » Sun Apr 07, 2013 11:11 am
Actually, to save time:-
The program Supersonic.exe version 1.0.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: 1d8c
Start Time: 01ce337f75fdf884
Termination Time: 64
Application Path: C:\Program Files\WindowsApps\61993AndreCarvalho.Supersonic_1.1.1.9_neutral__ds8y2a6qr665m\Supersonic.exe
Report Id: d8172e38-9f72-11e2-be93-00301bbcf1ad
Faulting package full name: 61993AndreCarvalho.Supersonic_1.1.1.9_neutral__ds8y2a6qr665m
Faulting package-relative application ID: App
Yanos
Postby andyoak » Sun Apr 07, 2013 2:28 pm
Yanos wrote:Actually, to save time:-
Process ID: 1d8c
Hum that error message is really generic. Whats really strange is that it happens when typing in the pasword box and not when actually trying to connect (correct..?).
You could try re-installing the app and just for testing typing in the password first and then the other fields. And also if you have any antivirus running try to disable it temporarily (in my pc I have Microsoft Security essentials)
If that doesnt work I've found this just googling a bit that could be your problem (if you are connecting via a proxy server) http://social.technet.microsoft.com/Forums/en-US/w8itprogeneral/thread/daa1a49f-95fb-4ab2-a64b-f1316d8bc1be/
andyoak
Postby rubbersoul » Mon Apr 08, 2013 12:35 am
I keep getting an error at login:
A method was called at an unexpected time (exception from HRESULT: 0x8000000E)
Could this have anything to do with me using music cabinet?
rubbersoul
Postby Yanos » Mon Apr 08, 2013 7:53 am
I added password first; and worked to the top of dialog box (entering server last) and it worked !....
Yanos
Postby andyoak » Mon Apr 08, 2013 2:06 pm
rubbersoul wrote:I keep getting an error at login:
Hello, I'm not sure. I dont use music cabinet.. Are you able to use other Subsonic client apps with your server? If you are, then it should be ok with Supersonic..
andyoak
Postby rubbersoul » Mon Apr 08, 2013 4:28 pm
Yes, I use android clients and the Web interface works
rubbersoul
Windows 8 client
Postby paulodell » Mon Apr 08, 2013 4:30 pm
rubbersoul wrote:Yes, I use android clients and the Web interface works
Are you using the latest version of music cabinet as when using SubWiji I noticed that the older versions had issues with the username and password being encoded, the latest version of music cabinet fixes this.
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Postby rubbersoul » Tue Apr 09, 2013 2:39 am
I am using the latest version (0.7.24c) and keep getting the error no matter which user I try to log in as. MiniSub, in addition to the android clients also works fine with the server.
rubbersoul
Postby andyoak » Tue Apr 09, 2013 9:10 am
Then it has no reason to not work. Can you please send me the logs like Paul did? See here http://forum.subsonic.org/forum/viewtopic.php?f=4&t=11801#p54726 Thanks
andyoak
Postby Yanos » Tue Apr 09, 2013 8:22 pm
Me again....
I've just installed on my Work Windows 8 Laptop - and get the same error.
I can't enter a server address - without the app locking up and crashing any ideas?
Fault bucket -726573796, type 5
Event Name: MoAppHang
Response: Not available
Cab Id: 0
Problem signature:
P1: 61993AndreCarvalho.Supersonic_1.1.1.9_neutral__ds8y2a6qr665m
P2: praid:App
P3: 1.0.0.0
P4: 515ec7d1
P5: de95
P6: 2097408
P7:
P8:
P9:
P10:
C:\Users\{username}\AppData\Local\Temp\WERA524.tmp.xml
C:\Users\{username}\AppData\Local\Temp\WERA534.tmp.WERInternalMetadata.xml
C:\Users\{username}\AppData\Local\Temp\WERA545.tmp.hdmp
C:\Users\{username}\AppData\Local\Temp\WERB8F5.tmp.dmp
These files may be available here:
C:\Users\{username}\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppHang_61993AndreCarval_d3dae92e9fe30365fc5a85eae8623c9649b72cd_79afd95d
Analysis symbol:
Rechecking for solution: 0
Report Id: e0c31e47-a152-11e2-be7e-ccaf78f0ae3e
Report Status: 16
Hashed bucket: fd5d60cbe7fe8165cc5be94dffc2ad6b
Yanos
Postby andyoak » Tue Apr 09, 2013 9:12 pm
Hi Yanos, that message doesnt really say anything usefull.. :) Can you send me the logs like I showed to Paul here http://forum.subsonic.org/forum/viewtopic.php?f=4&t=11801#p54726
andyoak
Postby Gido » Tue Apr 09, 2013 9:19 pm
He Nice,
Get a connection error, it connects because I see my A1 folder, after that it crashes.
Level: FATAL
Thread: 3
Logger: Application
The application crashed: Windows.UI.Xaml.Controls.Frame.NavigationFailed was unhandled.
System.Exception: Onherstelbare fout (Uitzondering van HRESULT: 0x8000FFFF (E_UNEXPECTED))
Level: ERROR
Thread: 3
Logger: ShellView
OnAdControlErrorOccurred
MicrosoftAdvertising.Shared.AdException: No ad available.
at MicrosoftAdvertising.Shared.AdPlacement.<SendAdRequestAsync>d__2c.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at MicrosoftAdvertising.Shared.AdPlacement.<RefreshAsync>d__26.MoveNext()
Level: ERROR
Thread: 3
Logger: ArtistsByFolderResult
Error interpreting data: {"subsonic-response": {
"status": "ok",
"indexes": {
"index": {
"name": "A",
"artist": [
"id": 313883,
"name": "A Balladeer"
"id": 313892,
"name": "A-Ha"
"id": 313869,
"name": "Abba"
"id": 313856,
"name": "ABC"
"id": 313887,
"name": "Absynthe Minded"
"id": 313853,
"name": "Acda en de Munnik"
"id": 313843,
"name": "Adam Lambert"
"id": 313837,
"name": "Adele"
"id": 313891,
"name": "Aerosmith"
"id": 313884,
"name": "After Forever"
"id": 313849,
"name": "Aimee Mann"
"id": 313886,
"name": "Air"
"id": 313895,
"name": "Air Traffic"
"id": 313903,
"name": "Akon"
Gido
Postby andyoak » Wed Apr 10, 2013 7:55 am
Hey Gido, thanks for posting the error. If I understood correctly, you have a top-level folder with sub-folders (artists) starting only with the letter "A". Is that right?
andyoak
Postby Gido » Wed Apr 10, 2013 7:07 pm
Hi andyoak,
Yes I do have folders like :
A1
B1
C1
E1
etc.
Under A1 I have all artitst ( bands ) started with a A
Under B1 I have all artitst ( bands ) started with a B
Under C1 I have all artitst ( bands ) started with a C
Under E1 I have all artitst ( bands ) started with a E
etc.
I don't use HTTPS and I use another port number than default.
Gido
Postby Skobone » Thu Apr 11, 2013 4:14 am
Crashed my Madsonic server when started to download album covers.
Subsonic 4.7 (build 3105)
AMD Athlon 64 3500+, 1 cores
1Gb DDR2
2tb Disk Ext4
Ubuntu Server 12.04.2
Skobone
Return to Announcements
