Subsonic 3.6.beta2 released
track lenght doubled
Postby oyvind » Fri Jan 30, 2009 7:33 am
I use to chop audiobooks in smaller 2-3minute tracks. When I use the "External player with playlist" or "Web player" the track lenght changeing to double size when played. eg. a 02:23 track become 04:46 when played.
This causes my player "PocketPlayer" to stop after each track when using "External player with playlist".
The "Web player" also double the track time but skip to next track when coming to the true end of the track.
I am unshure if this is a Subsonic problem or one caused by the "Audiobook Cutter FE" i use.
Anybody else seen this problem?
oyvind
Postby justin » Sat Jan 31, 2009 9:26 pm
Are you transcoding? :?:
if you go from 256 down to 128 it seems to trick the web player into thinking the track is twice as long.
justin
Postby justin » Tue Feb 03, 2009 9:15 am
Are you around oyvind? Try to turn off transcoding and see if that fixes the problem. I think thats was changes my time
justin
Postby oyvind » Tue Feb 03, 2009 9:47 am
justin wrote:Are you transcoding? :?:
You're right. I listen to audiobooks chopped into 3minute pieces and transcode them down til 32Kbps. When using "pocket player" it read the m3u file-list and the track-length is right until the player loads them, then it changes the lenght. When coming to the track-end the player stops. GSplayer have not the same problem.
If I transcode from 64Kbps to 32Kbps the time doubles, if the transcoding is less the time increases less.
It is the same for the WEB player.
oyvind
Postby justin » Tue Feb 03, 2009 11:17 pm
http://www.hydrogenaudio.org/forums/index.php?showtopic=58069
I think it has something to do with the way lame works. I'll try to find out more about the problem.
*edit*
I found a lot about this problem. I can't find anything about a fix or work around. Any one have pull over and at lame camp :P
justin
Previous
Return to Announcements
