Subsonic desktop Application
Postby martman » Thu Mar 04, 2010 6:57 pm
Great update! I can now download albums. Thanks for the great program.
martman
directory structure
Postby sietzebakker » Fri Mar 05, 2010 9:45 am
kn0pp1x wrote:I use Subsonic every day, and I think that I'll be using SubAir to interface with it from now on. Thanks for the work pha!
One suggestion/question. My subsonic is setup with multiple music folders in the settings (not the artist folders that are listed, but the actual setup of subsonic where I tell it the location on the hard drive of the media). Some of the folders are music locations and some are movies and TV shows that I have setup to stream with subsonic. The web interface gives me the option to select which folder I'm looking through at the top of the left panel, to avoid seeing both music and movies combined in one huge list, (Usually "all folders" or "music" in my case). With SubAir, I see all of my music and movies in one big list. Is there a way to select media from one of those locations at a time so that I only see my music?
Again, awesome app :)
Same problem! My directory structure is: Genre\artists\albums\track's
Great stuff!
sietzebakker
Re: SubAir
Postby sietzebakker » Fri Mar 05, 2010 9:50 am
pha9992001 wrote:
buellie wrote:great program
3 thoughts..might have been mentioned already..sory if they have been
1) be able to select which columns to show
2) turn on or off downloading
3) close/hide to notification area
thanks
(also how do you save a playlist?)
1. i can look into this
2. if the user doesnt have permission, the download will error out, but currently there is not error handling for this.
3. yeah, this has been mentioned previously.
Everyone can download while in subsonic download is blocked for that user!
sietzebakker
Re: SubAir
Postby pha9992001 » Fri Mar 05, 2010 3:28 pm
thanks
Not sure I understand this, but if the user does not have permission to download in subsonic, then the user will not be able to download from subair. Currently subair does not handle the error gracefully, but the download will not be successful.
pha9992001
Re: SubAir
Postby sietzebakker » Fri Mar 05, 2010 7:14 pm
thanks
See pictures and description on : http://picasaweb.google.nl/sietzebakker/SubAir#
sietzebakker
Re: SubAir
Postby pha9992001 » Fri Mar 05, 2010 10:20 pm
thanks
The file does not actually download. If you attempt to play the file nothing will happen. Subair currently just doesnt handle the error gracefully.
pha9992001
Postby pha9992001 » Fri Mar 05, 2010 10:25 pm
I just re-tested this, and i have found one bug that allows downloads, and this will be fixed in the next release.
The way around the download permissions is
1. user A with permission logs in and navigates to a directory
2. without navigating away for current directory, user B logs in
3. User B will be able to download for the current directory, but only if the directory has not be changed.
Other than that, a user without permissions will not be able to successfully download a file or directory. It will appear to be successful, but the file will not be playable.
pha9992001
Postby eli2k » Sun Mar 21, 2010 5:03 am
I tried to access subsonic through SubAir today outside of my network, using both IP and dyndns address. I get this error:
The trial period is over. Please donate to get a license key.
Any clues? I did try out the subsonic.org dyndns service but decided to stick with dyndns instead, and the trial as expired so I don't know if something's wrong here..
eli2k
Postby sindre_mehus » Sun Mar 21, 2010 10:02 am
Certain "premium" features of Subsonic requires a license key which you get by donating to the Subsonic project (this can be done from subsonic.org or click the red heart icon in the Subsonic web interface).
These features include:
- No ads in the web interface.
- Your personal name.subsonic.org address.
- Unlimited use of third-party clients (Android, iPhone, AIR)
- Access to future features, like video streaming.
The license key is valid for all future versions of Subsonic.
Hope this helps,
Postby buellie » Sun Mar 21, 2010 7:43 pm
My personal address doesnt work tho :(
buellie
Postby utopian » Thu Mar 25, 2010 2:29 pm
i just got the same thing with subair.. looking for a licence key..whats going on ??
utopian
Postby pha9992001 » Thu Mar 25, 2010 3:21 pm
utopian wrote:i just got the same thing with subair.. looking for a licence key..whats going on ??
please see Sindre's reply a few up from this one.
pha9992001
Postby utopian » Thu Mar 25, 2010 3:46 pm
so is subair a premium feature..i never realised... :(
utopian
Postby einsteinx2 » Thu Mar 25, 2010 4:11 pm
It's not that Subair itself is a premium feature, the API that Subair and the Android and iPhone apps use to connect is considered a premium feature.
einsteinx2
Postby utopian » Thu Mar 25, 2010 4:34 pm
ah right..ok donation on the way then :)
utopian
Return to Announcements
