4.7 beta
Re: 4.7 beta
Postby baxtr » Sat Jun 02, 2012 4:17 am
dewd wrote:The 4.7 beta incorrectly lists some artists. For example, in my collection I have "J. Geils Band" as the album artist (and track artist). Subsonic now displays it as "J". "R.E.M". is listed as "R.E".
I verified that the tags are correct. This is the same for both FLAC and MP3 files.
I'm running Subsonic on Ubuntu 11.10 Server.
I too see that running it on a vista machine, Seems it doesn't like the period....T.I is just T I have REM also, but no periods and it shows up, however Run D.M.C just comes up Run D.M
baxtr
Re: 4.7 beta
Postby gurutech » Sun Jun 03, 2012 2:53 am
Try renaming the folders to something else, then rename back to the original name. Sounds more like a Windows problem with the 8.3 naming convention than a Subsonic problem.
Folders don't technically have "file extensions" on them (otherwise they would be files!), so that's why I'm thinking it's more of a Windows issue...
gurutech
Re: 4.7 beta
Postby sindre_mehus » Sun Jun 03, 2012 7:45 am
I have reproduced it and can confirm that it´s a bug. Will be fixed.
Thanks a lot :)
Re: 4.7 beta
Postby MadEvil » Sun Jun 03, 2012 4:27 pm
Problem: Search/random Playlist
i found some bugs with lucense search
if i want get a random playlist from the More-Page it doesnt work, but only with some special genres.
Example: Drum & Bass, Hard Rock, rock, podcast
podcast: genre
will be sorted out because only MEDIATYPE.AUDIO is supported
drum & Bass: genre
only first words are indexed so the FIELD search doesnt work well
search with only drum or bass will work
Hard rock, rock: genre
same Problem: only first words are indexed, so if i search with rock, Hard rock will also be displayed
best regards
Madsonic Developer
MadEvil
Re: 4.7 beta
Postby mesc » Sun Jun 03, 2012 9:47 pm
GJ51 wrote:
mesc wrote:
GJ51 wrote:Sounds more like you may have a hardware or OS issue. I have (2) 4.7b1 instances on Windows that scan fine every night. I'd run chkdsk first then do a manual rescan to see if you can get any clues. Some hard drives start to break down as they age and the heat generated by intense prolomged disk activity is enough to put them over the edge. I'd also look at what kind of disk temperatures are being generated during the scan. HD tune pro or any similar disk monitoring software may be helpful for looking at the health of the hard drive(s).
Hm an OS issue? :) I don't think so... 4.6 runs stable. Checkdisk is fine, I've running Hard Disk Sentinel always in background and get reports every day via email about status of my fileserver. All fine. No problems with HD or temperature issues.
Also I wonder why Subsonic always freezez at the same position at media rescan. Btw this only happens on rescan, not on first time scan which runs fine.
Ok wizard. Then seeing as how you only divulge relevant information AFTER you ask the question I'll refrain from offering further suggestions so as not to waste your time. Good luck.
Uhm sorry GJ51. I just wanted some help.
mesc
Re: 4.7 beta
Postby mystery666 » Mon Jun 04, 2012 7:22 pm
Is beta 2 available yet? I saw a link a few posts up but it went to a gmail login and I'm hoping that was supposed to be a link to beta 2. I'm dying without playlists. Is there an emoticon with a noose?
mystery666
Re: 4.7 beta
Postby GJ51 » Tue Jun 05, 2012 6:57 pm
Not yet.
Re: 4.7 beta
Postby torgull » Wed Jun 06, 2012 6:15 pm
sindre_mehus wrote:Thanks for useful feedback and suggestions!
3. Maybe make it user-configurable whether to display album or directory name. (I'm slightly worried about adding yet another option, though).
Regards
I hope you can fix the 'problem'. A music player like subsonic that don't <DELETED BY MOD> my music is the reason is donated for a license.
with the new "feature" i cant see label, release year, source, flac/mp3 etc. which the folder normally shows.
looking forward to a new beta
Running VM Subsonic standalone, v4.6 on Debian with ESXi5.1 as host. 512mb memory limit
torgull
Re: 4.7 beta
Postby sindre_mehus » Thu Jun 07, 2012 9:22 am
MadEvil wrote:Problem: Search/random Playlist
podcast: genre
drum & Bass: genre
best regards
Well spotted! I've fixed the problem with multi-word genre now. I don't think the need for playing random podcasts is called for, so I'll leave that.
Thanks a lot
Re: 4.7 beta
Postby ytechie » Fri Jun 08, 2012 5:55 pm
Just wanted to chime in. Holy moly it has been a while since I contributed daily to the forum. Now that my semester is over I have a few weeks to work on subsonic once again. It will be less involved than before, because I am busy with Cisco stuff, but I feel like I should definitely start becoming more familiar with 4.7. I am way way way out of the loop!
To be honest, I am very nervous about 4.7 because I have made so many modifications that I am afraid I will lose them. That is why I am going to install 4.7 on a separate server with access to my media and slowly re-incorporate my mods, as well as test it. I have not seen or used 4.7 at all yet, and I can't wait until its release! I will slowly migrate all my code from 4.5 to 4.7, and will only retire 4.5 when I feel that everything is perfect. Otherwise I will be violating the rule which to me has become so sacred of: leave well enough alone.
Anyways, it is very exciting to see a 7-page thread just for one version of subsonic. This has been a long awaited version, and I haven't even read through its features yet. I have a lot of catching up to do, but I am so happy to have some time to do just that!
Cheers!
:D
ytechie
Re: 4.7 beta
Postby ytechie » Fri Jun 08, 2012 6:35 pm
OK. I am checking out 4.7 thanks to Gary ;)
First of all, it is clearly faster when loading pages, the issue that I have tried to fix but was really a backend problem. Wow!
The thing that I have spent hours doing by hand is removing the whitespace from the important pages like main.jsp, home.jsp, top,jsp, and left.jsp. I think that there is a way to do it server-side, but I don't know too much about the java server framework. With less whitespace, the pages can load even faster!
I have a lot more to check out, but I should be able to use the new framework and integrate my mods nicely.
Some issues I've noticed at first glance:
1) Starred feature is a bit slow.
2) Duplicate songs wil loop the playlist.
3) Videos have playlist features, but they can not be added to the queue. (Play All, Add All)
Can't wait to get started on the new version!! Sindre, somehow you manage to make the best even better! Thank you so much for your work, dedication, and expertise!
ytechie
Re: 4.7 beta
Postby ytechie » Fri Jun 08, 2012 9:40 pm
I just downloaded and installed 4.7beta2 on a separate server. There seems to be an issue with this title: Femme Fatale Deluxeï¦Britney Spears - 10 - Trip To Your Hear.mp3.
The whole album has that weird "i" after "Deluxe," and they show up as links and cannot be played.
There are a few albums like this.
Also, Settings > Personal - Display Browse.Year does not turn off the year when unchecked.
ytechie
Re: 4.7 beta
Postby GJ51 » Sat Jun 09, 2012 3:15 am
ytechie wrote:OK. I am checking out 4.7 thanks to Gary ;)
And once the video Playlist is created, it can't be deleted.
Re: 4.7 beta
Postby dewd » Sat Jun 09, 2012 3:34 am
Thanks a lot :)
Sweet! This has been fixed in beta 2. Thanks!!!
dewd
Re: 4.7 beta
Postby sindre_mehus » Sat Jun 09, 2012 2:58 pm
The first public beta version of 4.7 is now available so I'm locking this topic.
Please head over to viewtopic.php?f=4&t=9686
Thanks for all the useful feedback so far!
Previous
Return to Announcements
