Subsonic 4.7 released
Postby sindre_mehus » Fri Sep 14, 2012 5:33 pm
Subsonic 4.7 is now released.
Changes: http://subsonic.org/pages/changelog.jsp
Download: http://subsonic.org/pages/download.jsp
Thanks for all your feedback!
Re: Subsonic 4.7 released
Postby hakko » Fri Sep 14, 2012 6:00 pm
Thanks again for your continued work on this, and for releasing everything under the GPL! Much appreciated.
MusicCabinet developer
hakko
Postby GJ51 » Fri Sep 14, 2012 7:07 pm
4.7 final looks very solid. One nagging feature that needs to be addressed is the "Playing" screen. I don't understand why it would be too difficult to check that it is current whenever the player advances to the next track. This is particularly annoying when you que a various artists playlist. Now Playing just sits on the Album that contains the first track in the playlist and never changes.
Other than that minor whine, this is definitely the best Subsonic release to date!
Postby nunya » Sat Sep 15, 2012 1:22 am
Many Thanks for the great work.
nunya
Postby gurutech » Sat Sep 15, 2012 1:39 am
Finally time for me to upgrade! Only reason I delayed it is because I have the signature MOD and the registration MOD installed, and I'm dreading having to re-code them the way I have them now.
Anyone have advice on how to "save" existing MODs when upgrading, or will the 4.7 upgrade take this into consideration and not overwrite the modded files?
gurutech
Postby GJ51 » Sat Sep 15, 2012 1:54 am
Now you know why I don't mod ... :wink:
Actually, I run several sites always keeping one stock Subsonic as a baseline. All the sites access the same media library so using multiple sites allows me to play around without ever going down.
MadEvil's mod is the first that I've adopted for regular use as he keeps up with changes in the standard release and incorporates new releases with his mods. When I first tried getting into it for myself, I just got too frustrated trying to remember everything that had to be done to upgrade and finally just accepted that it wasn't worth the trouble.
I think Hakko has done great work as well and I hope to try his version soon.
But these are the only two that I've seen stick with it to the point that it made sense to use their work.
If you do use one of their versions, be sure to thank them for all their hard work via PayPal.
If anyone wants a look at MadEvils Mashup Mod, just send me a PM for guest logon.
HTH
Postby gurutech » Sat Sep 15, 2012 2:39 am
Well, I just ended up backing up the entire /var/subsonic folder, and my main website page, then did the upgrade. Haven't begun copying files back, but I get a "service unavailable" error when I try to access the site now.
I've restarted the subsonic service (but not the server, just yet), and the only "mod" I have done so far is to increase max memory to 200 from 150 (default), and chown the /var/subsonic folder (and subfolders) to "root"
gurutech
Postby willieb » Sat Sep 15, 2012 4:55 am
gurutech wrote:Finally time for me to upgrade! Only reason I delayed it is because I have the signature MOD and the registration MOD installed, and I'm dreading having to re-code them the way I have them now.
I would like that advice as well. I am running the registration mod and 2 instances on the same server.
And thanks greatly for the update!
willieb
Postby diffy » Sat Sep 15, 2012 12:37 pm
Thanks a lot for the amazing work on this project. Thanks a lot for providing this latest 4.7 stable version.
This software package, along with MyBB, Newscoop, Airtime and Vanillaforums are my absolute faves when it comes to
internet applications.
diffy
Postby wannabe_nerd » Sat Sep 15, 2012 4:40 pm
Great, Thank You Sindre, you certainly did a very good job there ^^
But there is still one Thing, which is really annoying: Evertime i scan my mediafolders the scanner stopps at a certain number of scanned files. i discovered, that it always stopps when subsonic tries to scan my videos-folders :-(
With version 4.6 i was able to disselect these foldes so just my music-collection was scanned. Afterwards i reselected the paths to my videofiles and everything was ok. but now with version 4.7 this workaround doesn't work anymore because if i do so, subsonic only shows empty folders :-(
Edit:
Ahhh i simply disabled the Fast-Access and now it's working fine with the described workaround :-)
Nevertheless i think the stopping of the mediascanning process is some kind of bug isn't it?
wannabe_nerd
Cloud Computing .... i made my own cloud !
wannabe_nerd
Postby foglera » Sat Sep 15, 2012 9:51 pm
Another user raised this issue in the beta thread:
I have installed the latest version of Subsonic recently ( 4.7.beta3 (build 3081)) and one of the changes bothers me a lot .
If there is no track number on the tag, album tracks are sorted in alphabetical order.
They used to be sorted by file name as well so if track number tag is missing, album tracks would still be sorted in correct order.
I'm aware of tag editors. I have a rather large mp3 collection and this task would be time consuming.
With previous release album tracks were sorted in a correct order regardless of having track number on the tag or not.
I'm in the same situation with my collection -- the switch from filename-based to tag-based indexing has made a shambles of my album organization and track order. Is it at all possible to toggle indexing back to the 'old' method, or otherwise have Subsonic fall back on filename-based indexing when tags aren't available?
foglera
Postby psychrome » Sun Sep 16, 2012 8:21 am
Is the issue discussed in the below post an expected behavior in 4.7 or something that will be fixed/changed?
viewtopic.php?f=4&t=9998&start=150#p45414
Currently no album art is shown for folders with no media and they are also sorted before folders with media...
My action is to either flatten my folder structure (remove CD1, CD2, ...) or wait for an updated release... :D
Apart from the above I think 4.7 is solid release...the best is getting better...
psychrome
Postby erik » Sun Sep 16, 2012 9:41 am
I just installed 4.7, and as with the previous betas, I just get a error 503 message when trying to connect to subsonic. I know this has been discussed elsewhere, but I don't remember seeing any solutions anywhere. Is there one?
erik
Postby hakko » Sun Sep 16, 2012 9:55 am
When HTTP ERROR: 503 occurs, have a look at the log files in (Program Files)/Subsonic/log/. There's probably some clue there. Paste it here for feedback.
hakko
Postby erik » Sun Sep 16, 2012 10:02 am
Subsonic-agent.log
1170 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@19e8329: display name [org.springframework.context.support.ClassPathXmlApplicationContext@19e8329]; startup date [Sun Sep 16 11:56:01 CEST 2012]; root of context hierarchy
1217 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-agent.xml]
1560 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@19e8329]: org.springframework.beans.factory.support.DefaultListableBeanFactory@165a43b
1747 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@165a43b: defining beans [service,agent,frame,settingsPanel,statusPanel]; root of factory hierarchy
Subsonic-service.log
281 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1e232b5: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1e232b5]; startup date [Sun Sep 16 11:55:29 CEST 2012]; root of context hierarchy
437 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
1326 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1e232b5]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1eae775
1373 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1eae775: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
2730 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files (x86)\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\3106
3307 [main] INFO org.mortbay.log - jetty-6.1.x
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/C:/Program%20Files%20(x86)/Subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/subsonic/jetty/3106/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
14196 [main] INFO / - Initializing Spring root WebApplicationContext
14196 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
14258 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@23f599: display name [Root WebApplicationContext]; startup date [Sun Sep 16 11:55:43 CEST 2012]; root of context hierarchy
14321 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
14399 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
14430 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
14461 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@23f599]: org.springframework.beans.factory.support.DefaultListableBeanFactory@138554d
16520 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@138554d: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,musicFileMemoryCache]; root of factory hierarchy
17706 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
125522 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@138554d: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,musicFileMemoryCache]; root of factory hierarchy
125523 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'podcastService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is java.lang.SecurityException: Access denied to file c:\music\Podcast\NRK P2 – Ekko - et aktuelt samfunnsprogram\nrk_ekko_-_et_aktuelt_samfunnsprogram_2012-0211-0514_6346447658.mp3
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.lang.SecurityException: Access denied to file c:\music\Podcast\NRK P2 – Ekko - et aktuelt samfunnsprogram\nrk_ekko_-_et_aktuelt_samfunnsprogram_2012-0211-0514_6346447658.mp3
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:99)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:79)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:140)
at net.sourceforge.subsonic.service.PodcastService.addMediaFileIdToEpisodes(PodcastService.java:213)
at net.sourceforge.subsonic.service.PodcastService.getEpisodes(PodcastService.java:184)
at net.sourceforge.subsonic.service.PodcastService.init(PodcastService.java:100)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
... 56 more
125655 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@9366ba{/,jar:file:/C:/Program%20Files%20(x86)/Subsonic/subsonic.war!/}
... 56 more
125808 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'podcastService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is java.lang.SecurityException: Access denied to file c:\music\Podcast\NRK P2 – Ekko - et aktuelt samfunnsprogram\nrk_ekko_-_et_aktuelt_samfunnsprogram_2012-0211-0514_6346447658.mp3:
127418 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:80
Subsonic running on: http://localhost/
127538 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
128557 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
129223 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.11.10:9412](local),objID:[0:0:0, 0]]]]
Hope this'll help. I tried uninstalling and reinstalling java, without any luck, btw.
Oh, and once again, thanks for helping!
erik
Return to Announcements
