Subsonic 3.5.beta1 released
Postby sindre_mehus » Sun Jul 06, 2008 2:08 pm
Hi folks,
Subsonic 3.5.beta1 is finally out! Some of the highlights are:
o A new Subsonic Mobile Player for streaming to mobile phones.
o Avatar support.
o Read-only mode.
o Many important bug fixes.
Complete change log: http://subsonic.sourceforge.net/changelog.html
Download: http://subsonic.sourceforge.net/download.html
Enjoy,
Great!
Postby Dante » Sun Jul 06, 2008 9:12 pm
Hi there Sindre!
I noticed that this version worked without X11 installed, so i had to test it!
Its working on my Mini-ITX (dual gbit LAN) running Ubuntu Hardy. (i've used the supplied packages with sun-java6-jre and lame)
Seems to be working great, will test it from work tomorrow :)
edit: btw, "allways use webplayer" is nice, but its missing the "detach player"-option you have when you select the webplayer manually.
Dante
Postby kapz » Fri Jul 11, 2008 1:31 am
Hi sindre
Thank you for continuing updating subsonic. I know your time is precious these days. I have been checking the new features in version 3.5 beta and here is some friendly feedback.
- When disabling the user from playing files, is there a need to see the bottom panel? Unless the user has the create/save play list permission, all that panel can do is load a saved play list.
Also, I think if a user can not play files, there should be no way to get to the "Settings" page. This is kind of a security issue. If I use the automatic login url you suggest, that user doesn't need to change the password or upload icons (since they will not see the icon).
***(BUG) If the limited user that can't play files creates a random play list, the music starts playing automatically.
- The avatar feature is cool. Would adding a small a small version of it in the “User” column of the status page be a good idea too? Are you storing the uploaded avatars in the DB?
- Merging same artists in the left panel is nice. I did have this problem, but removing the “all folders” category nullifies this (http://forum.subsonic.org/forum/viewtopic.php?t=897)
Many Thanks,
-kapz
kapz
Merging same Artists do not always work.
Postby kdid » Tue Jul 29, 2008 4:25 pm
On my system I have several entries in different folders for the same artist. This is true for A-ha. Some subfolders is named A-ha and others named A-Ha.
Now when the artist names is merged it shows only A-Ha and only one album. In other folders I have several albums with A-ha, but they do not show.
However I can make them show if I select only the folder they exist inside. But in the "All" folder, only part of the albums is listed.
I will attempt to send you a email with login information to my subsonic installation in case you want to take a look on what I mean.
-- kdid
kdid
Postby sindre_mehus » Fri Aug 08, 2008 9:14 am
Thanks for your feedback kdid and kapz, and sorry for the late reply.
I'll look into the issues you've brought to my attention.
download not working
Postby Lowryder » Fri Sep 05, 2008 1:11 pm
Hi
I have just upgraded from version 3.4 to 3.5 beta, but i have a problem with the new beta version regarding the downloads.
When i try to download something, and i have tried both entire albums and single songs, I only get a file with the correct filename and in mp3-format, but the filesize is only 160kb, and offcourse the song cant be played. It seems like the download only transfers the songtitle and fileformat (and maybe ID´tacks... i dont know about that), but not the contents of the file. Both from the player and directly from the filelist the result is the same.
The download pop-up-box states for exampel a filesiza of 14mb but when download completes after 1/2 a second the filesize is 160kb.
The download function worked perfect before the upgrade. Now i can only stream and not download. Is there anyone else having this problem?
The upload function is working fine btw.
Is it a bug or something I can fix myself somehow? If i cant fix it, i will have to go back to the previous version again :?
Lowryder
Re: Subsonic 3.5.beta1 released
Postby jigsaw » Sun Sep 07, 2008 6:00 pm
sindre_mehus wrote:Hi folks,
o Avatar support.
o Read-only mode.
Enjoy,
Hi Sindre
I have created an updated version of the Norwegian translations if you'd like to include it in the final release of 3.5 =)
I've added the new properties from the English 3.5.beta1 version and translated them.
You can download it here.
jigsaw
Postby sindre_mehus » Mon Sep 08, 2008 9:04 am
Thanks a million, jigsaw! That's really helpful :-)
I'll include it in the 3.5 release.
Cheers,
Postby braddyo » Wed Sep 10, 2008 5:21 pm
I love the new features. I can't seem to save playlists anymore. Was that moved?
Edit: Oh, haha. This is a fresh install and I forgot to allow myself to create playlists. Oops
braddyo
Return to Announcements
