Subsonic 5.0.beta1 released
Postby sindre_mehus » Sat May 24, 2014 5:45 pm
Hello.
Subsonic 5.0.beta1 is released with the following changes:
New: Chromecast support.
New: Added play overlay button in cover art images.
New: Added browser notification.
New: Nicer scrollbar (in Webkit browsers).
New: Nicer styling of input fields and buttons.
New: Nicer icons.
New: Added Estonian translation, courtesy of Olav Mägi.
New: Added Korean translation, courtesy of Rhetor Choi.
New: Added link to Jamstash.
Bugfix: Fixed broken Mac installer.
Bugfix: External player doesn't auto-advance.
Bugfix: Improved support for https in UPnP.
As always, looking forward to your feedback!
Re: Subsonic 5.0.beta1 released
Postby gwadafix » Sat May 24, 2014 7:09 pm
great thanks you so much Sindres 8)
gwadafix
Postby ebasta » Sat May 24, 2014 10:45 pm
Working good so far - have not been able to test Chromecast yet. Feature Request: In addition to having the left column list artists, can there be a drop-down or radio button to list albums?
ebasta
Postby GJ51 » Sun May 25, 2014 2:37 am
Video playback doesn't begin when pressing the play button from the file list. It pops up the video player and then requires a second click on the player to initiate playback.
Attempting to play a second video puts the player in black void. Refresh required to play another video.
Postby alphawave7 » Sun May 25, 2014 3:46 am
Chromecast works and looks great!
Requests: 'Float' the screensaver rather than stutter, which appears to have long delay and little movement.
and I would love the CC feature to apply to client machines rather than just the server (unless I'm doing something wrong...). Cheers Sindre!
Postby hs6666 » Sun May 25, 2014 9:39 pm
hi,
just installed
I used to have a transcoding problem with 4.9 from flac to mp3
I fixed it by creating a new transcoding line just for flac and using ....
"ffmpeg -i %s -ab %bk -v 0 -f mp3 -map_metadata 0:0 -"
instead off
"ffmpeg -i %s -ab %bk -v 0 -f mp3 -"
But since upgrading, this does not work anymore, I am again getting following error in logs...
DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/media/root/MUSIC/MUSIC/Manic Street Preachers/Forever Delayed/A1 - A Design For Life.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-map_metadata] [0:0] [-]
DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
any ideas please?
hs6666
Postby alphawave7 » Sun May 25, 2014 10:37 pm
ffmpeg was updated on 3/19/2014 for SS...have you tried going back to original script?
Postby hs6666 » Mon May 26, 2014 7:18 am
i extracted ffmpeg file from the 4.9 deb package and replaced the ffmpeg file in /usr/val/subsonic/transcode/ folder with the extracted one
but now on playpack i'm getting...
"Failed to transcode A Design For Life. Using original."
which doesnt then play in browser or on android phone?
Am i doing something wrong?
hs6666
Postby Exrace » Mon May 26, 2014 1:38 pm
Some feedback on the setup routine on Windows.
I performed an upgrade on my setup after moving the core dirs to a brand new server.
New server is Windows Server 2012 and had no java support.
After pointing the installer to my copied directory on the new server it detected no java installed and installed a compatible version automatically. The installer found my old DB and upgraded with no issues.
New interface graphics are looking better and performance has been great in many different web browsers and platforms.
On my setup all my files live on network shares so file paths remain the same.
Just keep in mind if you move your libraries around playlists will break.
Thanks Sindre!
Exrace
Postby freekdb » Mon May 26, 2014 7:44 pm
Nice to see about the chromecast support. Next thing is chromecast support in the android app I guess :)
But are you aware about the problem that some of us is having with DLNA?
viewtopic.php?f=2&t=14045
This new version does not solve it :(
freekdb
Postby ebasta » Mon May 26, 2014 8:22 pm
I have been having issues playing most m4a files. One or two seem ok. All mp3 files seem to play fine. I do not know what the m4a's have in common yet.
ebasta
Postby hawkinsb » Tue May 27, 2014 12:34 am
This is a major bummer. I was really hoping 5.0 would fix this DLNA problem. I tried it and agree that it's still broken. Not sure how anyone is using the feature until this is fixed...
hawkinsb
Postby ebasta » Tue May 27, 2014 5:20 am
The m4a files that will not play in the playlist have a curious output. In the playlist list, between the year and the file size is this string "ogg oga aac m4a flac wav wma aif aiff ape mpc shn" where I believe it should just be "m4a".
ebasta
Postby alphawave7 » Tue May 27, 2014 5:34 am
I've been using BubbleUPnP app (android) on my Nexus 5 and 7 tablet as control points to send from Subsonic to my renderers. Works a treat.
Postby Exrace » Tue May 27, 2014 6:00 am
I can confirm DLNA doesn't work with windows 8.1 media player.
The player finds server but "no files found" message when you browse for music.
Exrace
Return to Announcements
