Subsonic 3.6.beta1 released
Postby sindre_mehus » Mon Jan 05, 2009 2:27 pm
Happy New Year, everybody!
Please notice that 3.6.beta1 was released today. There's quite a lot of new stuff, but most importantly:
o Fully integrated embedded Flash player.
o Ajaxified playlist page, avoiding those pesky reloads.
Complete change log: http://subsonic.sourceforge.net/changelog.html
Download: http://subsonic.sourceforge.net/download.html
Enjoy,
Postby zeekay » Mon Jan 05, 2009 3:20 pm
Wow! Awesome, thanks sindre! Lovely release, 3.6 is looking great! Beta out sooner than I had thought, :D
zeekay
HI
Postby sheridan » Mon Jan 05, 2009 5:31 pm
I 've tested Subsonic 3.6 Beta 1
I've updated my stable version 3.5 with latest beta version and i had a little problem with album thumb. I hane no album cover
Is it a bug ?
sheridan
Postby aphuey » Mon Jan 05, 2009 6:28 pm
I had this same problem, but it went away when I updated my version of Java. You'll want to warn your users that they may have to update their Java as well...
aphuey
Postby aphuey » Mon Jan 05, 2009 6:31 pm
Nice improvements, Sindre!!
It looks like the "Now Playing" info on the right also stays current through the whole track that the users are playing, as well (instead of disappearing as soon as it had buffered). This is a HUGE improvement! Did this take some work on your part or just a bi-product of the other changes?
Either way - I think it's a great improvement!
aphuey
Postby justin » Mon Jan 05, 2009 6:32 pm
Great Job. I installed it over 3.5 and everything seems to work.
For some reason the player always seem to think the song its playing is twice as long as it is. It still goes to the next song when it should so its not a big problem.
justin
Postby aphuey » Mon Jan 05, 2009 6:43 pm
justin wrote:Great Job. I installed it over 3.5 and everything seems to work.
I'm not having that problem. The song duration in the player matches the duration in the playlist and when it is halfway through the song, the slider is halfway to the end of the bar...
aphuey
Postby justin » Mon Jan 05, 2009 6:56 pm
Ill try a clean install and see if it is fixed
justin
Postby sindre_mehus » Mon Jan 05, 2009 7:42 pm
aphuey wrote:I had this same problem, but it went away when I updated my version of Java. You'll want to warn your users that they may have to update their Java as well...
Yeah, that's right. I forgot to mention that. To be precise, the Windows installer version now requires Java 6 or later. (The standalone and war versions are still on Java 5 or later).
It's mentioned in the installation instructions and the changelog, and now here in the announcement.
Thanks for reminding me.
Postby sindre_mehus » Mon Jan 05, 2009 7:44 pm
aphuey wrote:It looks like the "Now Playing" info on the right also stays current through the whole track that the users are playing, as well (instead of disappearing as soon as it had buffered). This is a HUGE improvement! Did this take some work on your part or just a bi-product of the other changes?
It's not by chance, no :-) There is now a 60 minute history on the Now Playing information.
Postby sindre_mehus » Mon Jan 05, 2009 7:49 pm
justin wrote:For some reason the player always seem to think the song its playing is twice as long as it is. It still goes to the next song when it should so its not a big problem.
If the problem persists can you please email me an example audio file which demonstrates it?
Cheers, Sindre
Postby justin » Mon Jan 05, 2009 8:30 pm
Some time the songs time will jump from 9:02 to 9:03 and back. This is going on with every song i have.
I did an uninstall and reinstall and that didn't fix it.
Edit
It seems to only happen when its transcodeing the song. The image above is going from 320 to 128 if that helps
justin
Postby justin » Mon Jan 05, 2009 9:48 pm
Small Crash when non admins click
To change or remove this message, log in with administrator rights and go to Settings.
Exception java.lang.NullPointerException
Message null
Java version Sun Microsystems Inc. 1.6.0_07
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 37 of 39 MB
Stack trace java.lang.NullPointerException at org.acegisecurity.ui.ExceptionTranslationFilter.handleException(ExceptionTranslationFilter.java:229) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:176) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:139) at org.mortbay.jetty.Server.handle(Server.java:313) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:506) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:830) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:381) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:396) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442)
justin
Postby sindre_mehus » Mon Jan 05, 2009 9:53 pm
justin wrote:Small Crash when non admins click
Ah, thanks. I'll look into that.
Standalone still shows I'm running 3.6 after installing 3.6
Postby mgrant » Mon Jan 05, 2009 10:19 pm
I was running the linux/tomcat version. Then i switched to the standalone version. Today I installed 3.6 but the main page still says:
Note! A new version is available.
Download Subsonic 3.6.beta1 here
And the help button shows I'm running 3.5 build 709.
I think I must have botched the switch from tomcat to standalone somehow.
-mg
mgrant
Return to Announcements
