Subsonic 5.0.beta2 released
Re: Subsonic 5.0.beta2 released
Postby sindre_mehus » Sun Sep 07, 2014 1:08 pm
xtxer wrote:Has anybody found a way to set a default Kbps for videos? It's defaulting to 200 for me. Simple enough to manually change it since I know what it means, but now my friends and family that aren't tech savvy think that videos look worse suddenly lol
Sorry about that. Will fix it to default to 2000 Kbps as was the intention.
Postby sindre_mehus » Sun Sep 07, 2014 1:09 pm
MediaHive wrote:Hi,
I have an issue on the Startpage.
A screenshot is in the attachment.
Greetings
Hyper
Try to clear the browser cache and reload the page.
Postby sindre_mehus » Sun Sep 07, 2014 1:11 pm
dirkal wrote:Looks like the Playlist Edit feature is now a bit wonky. None of the boxes are mouse selectable anymore. It all now appears a bit greyed out. The text boxes are able to accept info, however navigation is only possible via Tab key. Is anyone else experiencing this issue?
An unfortunate side effect of upgrading the jQuery UI library. I've fixed it now.
dirkal wrote:Also did this update address the Java 7 incompatibility?
Do you have any more information about this? Not sure what you refer to.
Postby joost » Sun Sep 07, 2014 2:25 pm
@sindre: Is there going to be a fix for upnp?
joost
Postby sindre_mehus » Sun Sep 07, 2014 3:03 pm
rboshuis wrote:Is there a way to cast all songs to the chromecast? Currently only a single song is send to the chromecast.
I understand that the song is probably directly retrieved rom the Subsonic server, but may be the client could send (after the total time of the song), the following request to the chromecast?
rgds,
Ronald
The Chromecast should auto-advance to the next song in the play queue (but the web page has to be open). Does this not happen on your system?
Postby airjrdn » Sun Sep 07, 2014 4:50 pm
I updated a week or so ago, and also changed the location of my music and my playlists are now empty. As I understand it though, the playlists are in the database. Given that the location of the music changed, I had to fix that in Subsonic. Is there a way to get my playlists back? Even if I have to edit them to change the base locations of the files, it will be better than just losing them.
airjrdn
Postby MediaHive » Mon Sep 08, 2014 8:09 pm
sindre_mehus wrote:
MediaHive wrote:Hi,
Greetings
Hyper
as I found out this was due to my welcome message which included "#" characters.
Could you add the possibility to change the standard column width for a user?
Greetings
Hyper
MediaHive
Postby idealog » Wed Sep 17, 2014 10:32 am
[quote="daneren2005"][quote="HippopoKiboko"]And still present bug. Nobody can't download files with unicode names.
It is terrible. This bug is present during SIX(!) years. :twisted:
If you can't fix this bug maybe you should write about this?
i.e. "If you are using non-english names for files please don't use the subsonic"? :?
viewtopic.php?f=2&t=1424&start=15#p59187[/quote]
Well that's a bit silly. While it definitely should be fixed, its not like downloading is even remotely the point of subsonic. He could take it out altogether and I doubt more then a few percent of users would even notice.
Sent from my Nexus 5 using Tapatalk[/quote]
Just though it would be worth mentioning that, whilst I might indeed be part of a minority, the download capability is very important to me. I regularly use DSub to download music from my Subsonic library to my phone's SD card for offline listening.
idealog
Postby Aethies » Thu Sep 18, 2014 6:25 pm
It has been a while since i have been on here... My server had a catastrophic failure. After a huge donation from a good friend of mine, the server is back online.
Here is the issue... I was down over a month and so was no big deal, but after coming back online, everything was back to normal. Then I updated to the new Subsonic 5.0Beta2. After updating to that version, all the roku's no longer will play video. I haven't changed anything on the server side, but I did notice a change log line where you said you fixed some ffmpeg command.
Bugfix: Updated ffmpeg commands to fix some transcoding issues.
I don't want to think that was what caused the problem, but I am at a loss at what it could have been.
Here is my transcoding line which is also set for the Roku's
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -vcodec libx264 -preset superfast -threads 0 -
Mind you, this has worked flawless for a long time. I am also pasting some log files in here where this was happening.
[2014-09-17 12:48:14,953] INFO PlayQueueInputStream - xxxxx listening to "xxxxx.avi"
[2014-09-17 12:48:14,959] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [700] [-t] [10] [-i] [/xxxx.avi] [-async] [1] [-b:v] [1914k] [-s] [720x304] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [mpegts] [-c:v] [libx264] [-preset] [superfast] [-c:a] [libmp3lame] [-threads] [0] [-]
[2014-09-17 12:48:14,970] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version 0.8, Copyright (c) 2000-2011 the FFmpeg developers
[2014-09-17 12:48:14,970] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Sep  5 2011 21:24:46 with gcc 4.4.3
[2014-09-17 12:48:14,970] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-libfaac --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-x11grab --enable-libmp3lame
[2014-09-17 12:48:14,970] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    51.  9. 1 / 51.  9. 1
[2014-09-17 12:48:14,970] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   53.  7. 0 / 53.  7. 0
[2014-09-17 12:48:14,970] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  53.  4. 0 / 53.  4. 0
[2014-09-17 12:48:14,971] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  53.  1. 1 / 53.  1. 1
[2014-09-17 12:48:14,971] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   2. 23. 0 /  2. 23. 0
[2014-09-17 12:48:14,971] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    2.  0. 0 /  2.  0. 0
[2014-09-17 12:48:14,971] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2014-09-17 12:48:15,031] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [avi @ 0x9a49340] non-interleaved AVI
[2014-09-17 12:48:15,033] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mpeg4 @ 0x9a4b200] Invalid and inefficient vfw-avi packed B frames detected
[2014-09-17 12:48:15,034] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)
[2014-09-17 12:48:15,034] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65534/2733) -> 23.98 (10000000/417083)
[2014-09-17 12:48:15,034] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, avi, from '/xxxx.avi':
[2014-09-17 12:48:15,034] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 02:45:18.40, start: 0.000000, bitrate: 1914 kb/s
[2014-09-17 12:48:15,034] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Video: mpeg4, yuv420p, 720x304 [PAR 1:1 DAR 45:19], 23.98 tbr, 23.98 tbn, 23.98 tbc
[2014-09-17 12:48:15,034] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s
[2014-09-17 12:48:15,037] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Unrecognized option 'b:v'
[2014-09-17 12:48:15,226] INFO PlayQueueInputStream - xxxx listening to "xxxxx.avi"
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Previous
Return to Announcements
